Air Shock problems GL 1500 - Steve Saunders Goldwing Forums
  • 1 Post By Jerry Burns
post #1 of 5 (permalink) Old 01-06-2018, 07:46 PM Thread Starter
Model: 1993 GL 1500
Today I pulled the rear end to grease the splines of the drive shaft, and the eyelet on the bottom of the air shock is broken. I have a set of air shocks off my old gl1200 ltd. that are in very good condition. So I'm thinking of using them. I will have to build a manafold so I can hook up both shocks. I have the air lines and fittings so it should be pretty easy. I also thought of just using 1 shock and leave the spring shock on the other side like it was stock. It's to late now to do anything so I thought I would ask you guys and maybe someone has tired this. Thanks for your insight.
Jerry Burns is online now
post #2 of 5 (permalink) Old 01-06-2018, 08:01 PM
I would stick with the OEM shock. (air shock) (Air cushion) It's all engineered to go together. Can be had for $50 on eBay.
redwing52 is offline
post #3 of 5 (permalink) Old 01-06-2018, 08:19 PM
Pure Texas's Avatar
Make: Goldwing
Redwing,who did you work for on big rigs?
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is offline
post #4 of 5 (permalink) Old 01-07-2018, 01:18 AM
Kimberly Clark, Schneider then the City...
post #5 of 5 (permalink) Old 01-09-2018, 08:51 PM Thread Starter
Model: 1993 GL 1500
Just a follow up on the shocks, when I pulled the Air shocks off the LTD I set them up so the fluid wouldn't come out and took a picture of them thinking I would sell them. Well the wife laid them on there side and all the fluid came out. I had to take them apart to put fluid in and clean them out. I decide to only use one of the shocks like the gl1500 and installed it . Every thing went back together like stock and seems to be really good. I also installed the new Dunlop e4 and greased the splines on the drive shaft. I changed the oil in the final drive and cleaned everything so the bike is back together but I can't get it out to ride it for a little bit. Rained today and I have to drive it out when the ground is dry or I'll tear up the grass. That E4 tire looks really mean, just a side note because I don't know how it will handle yet but it looks good. LOL
redwing52 likes this.
Rear 1500 air shock kevink Goldwing Technical Forum 1 10-11-2014 10:12 PM
1500 SE air shock boot Buzzden Goldwing Technical Forum 5 11-14-2013 01:26 PM
78 GL 1000 s and w mk3 air shock problems drfritch Goldwing Technical Forum 2 08-11-2011 06:31 PM
1990 SE Rear Air Shock problems charz Goldwing Technical Forum 5 07-08-2011 12:28 PM
1500 air shock. gumbyred Goldwing Technical Forum 10 12-16-2009 09:58 PM
