1980 Honda GL1100 Clunking Noise - Page 2 - Steve Saunders Goldwing Forums
 9Likes
post #11 of 67 (permalink) Old 01-15-2018, 09:25 PM
Pure Texas's Avatar
Make: Goldwing
Yep it's been like eight hours. M
Shirley enough time to put in a days work and spend a few hours on his hobby.
O yeah,if I wanted it fixed that would be plenty o time for me.
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is offline
post #12 of 67 (permalink) Old 01-15-2018, 10:26 PM Thread Starter
Hellathos's Avatar
If you have not synched the carbs do that first. Sounds like primary chain rattle from here.
Haven't synced the carbs and I'm a noob so I'm looking into making a diy kit soon to do it.
Sent from my XT1254 using Tapatalk
Hellathos is offline
post #13 of 67 (permalink) Old 01-15-2018, 10:26 PM Thread Starter
Hellathos's Avatar
Originally Posted by Pure Texas View Post
Or maybe the splines in the rear wheel taking up slack from wear
Not sure what the splines are, but I'll Google it.
post #14 of 67 (permalink) Old 01-15-2018, 10:27 PM Thread Starter
Hellathos's Avatar
It doesn't seem to be in gear.
Nope, in neutral.
post #15 of 67 (permalink) Old 01-15-2018, 10:29 PM Thread Starter
Hellathos's Avatar
Seems too loud and erratic for the primary chains.
Clutch basket or maybe a busted damper plate.
I'll check into those, but does the primary chain connect to the starter sprocket? I've had to replace the starter to get it running again. You think I may have the sprocket sitting in the chain wrong? I know it tilts when you take it the starter, but I didn't think I'd be able to put it back on unless I had everything lined up properly.
post #16 of 67 (permalink) Old 01-15-2018, 10:31 PM Thread Starter
Hellathos's Avatar
How many miles on the motor? Thatís loud,does it go away with rpm?we donít hear from too many bad clutches,on the left rear of the motor thereís a cap that covers the bolt that hold the stator tight,look at that and assure itís tight,if the rear wheel is turning while itís running (sometimes it will while in neutral) step on the brake and see if it stops,if it quiets with rpm,the chain could be bad but most time the motor will have a lot of miles on it.
Describe how you synced the carbs,they would have to be way out for it too be that loud and it would rattle on idle.
Odometer reading is 64028. When giving it throttle with the clutch held in it revs like a champ with no knocking, but letting out the clutch and revving makes it louder. Is that the metal cover that looks like it takes a giant Flathead? Looks tight.
post #17 of 67 (permalink) Old 01-15-2018, 10:32 PM Thread Starter
Hellathos's Avatar
Rattles on idle with clutch out.
post #18 of 67 (permalink) Old 01-15-2018, 10:33 PM Thread Starter
Hellathos's Avatar
The bad news is whatever it is the issue is deep inside. I am less sure it is the primary chain as it turns all the time. Clutch in or out. I think it is more likely an issue with a bearing or gear in the transmission. The first thing I suspect is you have a bent shift fork. Start the bike and hold the clutch in. At the same time shift the transmission through all the gears. Does the noise go away. Usually 4th and/or 5th is the issue. Maybe try putting the bike on the centerstand and rotate the rear wheel in neutral. Use quick motions back and forth as well as rotating normally in both directions. Can you hear a clunk or other noise then? This test eliminates the chain. The transmission gears only rotate when the clutch lever is out when the engine is running. . You might start by taking the clutch out but I am afraid the issue is deeper inside and the engine will need to be removed. Sad because the motor seems to run really well.
It's in neutral and I've played with the tire, but I can't get it to budge with my hand. Tried playing with neutral a bit, but no change.
post #19 of 67 (permalink) Old 01-15-2018, 11:44 PM
Yes, there definitely could be a connection to the noise and the starter.
Please update your profile to include your city, state and bike info.
post #20 of 67 (permalink) Old 01-15-2018, 11:57 PM
Highly doubtful.
Don't do it. Dennis is the head of an Oldwing theft ring. You give him even a hint of where you are and what you've got and you'll be Wingless.
Ken Bergen is online now
Help Please Clunking Noise McFirefighter Goldwing Technical Forum 6 05-30-2017 06:50 AM
Clunking noise john424 Goldwing Technical Forum 10 01-28-2015 08:49 AM
1500gl clunking noise ozzy74 Goldwing Technical Forum 8 07-27-2014 11:56 PM
84 GL1200 clunking noise duncan427 Goldwing Technical Forum 14 06-16-2011 10:39 AM
Clunking noise revalator Goldwing Technical Forum 3 04-19-2009 09:53 PM
