'99 Oil leak question - Page 2 - Steve Saunders Goldwing Forums
post #11 of 12 (permalink) Old 01-18-2018, 12:15 AM
Terry: Have you identified approximately where the oil is originating or should we just keep making wild guesses?
Ken Bergen is offline
post #12 of 12 (permalink) Old 01-18-2018, 12:56 AM
John J's Avatar
Year: 2006
Make: Honda Goldwing
Model: GL1800A6
[QUOTE=tlbranth;5552978]'99 GL1500SE. 144,000 miles - runs like a top. I've had an oil leak for a while and now I'm trying to find its source. Oil is quite wet on the coolant drain plug and the water pump cover is oiliest on the clutch side of the bike. There's oil on the crankcase but it's dry, oil down the side of the engine on the clutch side - drier the farther back it goes. Hard to see but I'm reasonably sure it's not a head gasket leak. I'm thinking it's the o-ring on the water pump.
Terry. Here's a picture of an oil leak from the water pump seal. Does your pattern/spread look similar? The drain plug looks drier on this one than you describe on yours.
GL1800A 2006
Previously:
GL1500SE \'98
Harley Fatboy 2004
Triumph Rocket Touring 2010
Pan European ST1100
John J is offline
1986 GL1200A Final Drive oil leak at swing arm boot - part question eskachig Goldwing Technical Forum 20 04-27-2015 01:02 AM
GL1200 final drive oil leak - parts question eskachig Goldwing Technical Forum 4 03-24-2015 01:30 AM
Oil Leak source question harkgold Goldwing Technical Forum 29 07-11-2014 02:49 PM
Drive shaft oil leak - Question answered snowman6454 Goldwing Technical Forum 3 11-20-2008 07:20 PM
1979 GL1000 oil leak question TxMike Goldwing Technical Forum 22 08-25-2005 09:20 AM
