Lexan Refinishing. - Page 6 - Steve Saunders Goldwing Forums
 12Likes
post #51 of 77 (permalink) Old 02-06-2018, 05:59 PM
I think mine are worse than yours.
I definitely need to get to work on them.
The car was garaged for most of its' life, and the headlights were pretty clear until two years ago. Then we filled the garage with "honey do" projects and it has been outside ever since.
Wow, what a difference two years makes on headlights.
What is your opinion, think it will have to be sandpapered first?
post #52 of 77 (permalink) Old 02-06-2018, 07:29 PM
BLUTHUNDR31's Avatar
naw, , , rubbing compound, polish/buffing compound first. . . you risk nothing by trying the "softer" approach first, , ,(except for a little time/elbow-grease)
IF you need sandpaper, you might not have to start out with the coarser grits, , , probably start with 800-1000 grit.
BTW, , , amazon has a $10 packet of 3 inch sandpaper grits (5 pieces at 6 grits for total of 30) and the velcro style cushioned pad for the drill. Good way to save some bucks. . .
BLUTHUNDR31 is offline
post #53 of 77 (permalink) Old 02-07-2018, 08:17 AM
cihilb's Avatar
Model: 2012 Pearl White
Originally Posted by Bluthunder View Post
After I clean up the back-up windshield, I'm planning on doing the Tahoe headlights, , , the PO must've parked headed-in against thick bushes ALOT!!!
John, are the headlights on the Vibe this bad?? Looks like I'll try the rubbing compound first, , , , but a nagging feeling makes me think it'll be sandpaper-time if the results aren't any good.
DRIVER HEADLIGHT
PASSENGER HEADLIGHT
I know you want ot try and save some money, but this company has replacement headlights for most of the older vehicles and the prices aren't bad. Considering the amount of time and work ti takes to refinish the old lights, you can replace them with NEW.
https://www.headlightsdepot.com/
cihilb is offline
post #54 of 77 (permalink) Old 02-07-2018, 01:33 PM
Good info Cihilib, , , I looked mine up & they run $115 EACH+ free shipping, , ,
Retired, on a fixed income means I got a Helluva lot more "time" than money and a $10-27 expense is right in my "wheel-house". Each light might take an hour or two, , ,besides mama sees me outside working and is reluctant to think of any more "honey-do" crap
post #55 of 77 (permalink) Old 02-07-2018, 03:50 PM
That's $222.00 for a set for my car, but they are listed as "out of stock".
that is comparable to what I paid J.C. Whitney for a set for our 2005 Vibe, which lasted us about 4 weeks because a buck deer totalled out that car...
sad story on that type of headlight.
the up/dn adjustment screw is buried deep inside the assembly, and if you run it too high, it falls off the screw threads and the beam drops all the way down to the bumper....
how do I know this? I was adjusting the passenger side and had it "almost right" and thunk! it fell off the screw.......... I was pissed, a brand new headlight, totally useless.
and what is worse, to get to the screw that secures it to the body, requires you to remove the entire front end, grill, bumper, and side fender skirts.
post #56 of 77 (permalink) Old 02-07-2018, 04:34 PM
Now, , , if you put Hydraulic shocks (like the "low-riders" used to do 'round here) on that car, you could point them lights as hi or low as you wanted!!!! PROBLEM SOLVED
AZgl1800 likes this.
post #57 of 77 (permalink) Old 02-09-2018, 07:43 PM
The 1000 grit would've worked for the oxidation but did NOTHING about those "brush scratches". I had to begin with 240 grit and work my way up to 5000 grit. After the rubbing compound/polishing compound the headlights are "like new".
post #58 of 77 (permalink) Old 02-09-2018, 09:25 PM
gives me hope, but too cold right now.
post #59 of 77 (permalink) Old 02-12-2018, 08:51 PM
Pure Texas's Avatar
Make: Goldwing
When sanding,put a tablespoon of dishwasher soap in your water ,keeps the wet/dry sandpaper from clogging and not scratch so much,400 works good for starts and then the higher grit.
This will polish the plastic fine after sanding after 1000 sanding
Power buff at under 1600 rpm,don’t want to get it hot
File Type: jpeg C8543852-50FA-4A2C-B2A9-E6817C57E4FF.jpeg (13.5 KB, 14 views)
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is offline
post #60 of 77 (permalink) Old 02-12-2018, 09:07 PM
YEP, , , I dribble some DAWN liquid dish soap too, seems to work well.
Thanks for "sharing" Pure Texas, , ,wasn't trying to keep a secret, , just forgot to include that in my tips.
Making holes in lexan/plastic Chewman Goldwing Technical Forum 19 12-18-2017 08:20 PM
Windshields: Acrylic, Lexan, Lucite. Preference? Recycled Roadkill Goldwing Technical Forum 12 07-29-2014 11:02 AM
1/8" thick lexan...Can I use this thickness for a windshield on my '87 interstate? foreck Goldwing Technical Forum 17 10-23-2013 06:17 PM
heating and molding lexan desert wings General Motorcycle Discussion Forum 16 02-11-2012 07:29 PM
Refinishing Chimp General Motorcycle Discussion Forum 12 10-22-2008 10:34 AM
