For what it's worth - Page 3 - Steve Saunders Goldwing Forums
 7Likes
post #21 of 29 (permalink) Old 01-24-2018, 07:39 PM
If you would put a Battery Tender on every time you get home, the next time you let it sit for 3 weeks, or 3 months, it will start the first time.
post #22 of 29 (permalink) Old 01-25-2018, 05:51 PM
Screw's Avatar
Model: GL1200 and GL1100
Might have nothing to do with it but is it sitting on the center stand or kick stand?
Screw is offline
post #23 of 29 (permalink) Old 01-25-2018, 08:31 PM Thread Starter
Sticks's Avatar
Year: 1995
Model: 1995 GL1500 SE
always on the center stand
Screw likes this.
Forgive others. Not because they deserve forgiveness, but because you deserve peace.
If your not willing to forgive others, how can you expect God to forgive you.
Sticks is offline
post #24 of 29 (permalink) Old 01-29-2018, 07:55 PM
tlbranth's Avatar
Year: 1999, 1975
Model: GL1500SE GL1000
My 1500 has to be cranked a while if it's been sitting a long time - like a month, not a few days. I try to run bikes fairly often. They really don't like to sit for long periods. I'm not sure why. But when I put a bike back in the shed after a run, I always put marine Stabil in the tank and run it enough to get in in the carbs. On the 1500, I'm guessing the fuel in the carbs evaporates and I have to crank 'til I refill them. I don't know much about women either.
Terry
Don't own a Vanagon.
Don't work at Boeing.
Life is good.
1970 CB750
1975 GL1000
1999 GL1500 SE
2002 VT750
tlbranth is offline
post #25 of 29 (permalink) Old 01-30-2018, 12:37 AM
you are quite right on the fuel evaporating from the carbs.
If, the vacuum fuel shut off valve were replaced with an electric one, and then a switch was added with a relay to isolate the ECM from reverse power, you could "prime the carbs" before a start....
push prime button, count to 10, turn key on, hit start button and varoom!
that way, it could sit for a year, and still start up just like it was yesterday the last time. although, if it sat for a year, there could be more than just "no fuel" gone wrong.... bikes don't like to sit, as you mentioned.
post #26 of 29 (permalink) Old 01-30-2018, 09:43 AM
tlbranth's Avatar
Year: 1999, 1975
I think there's a benefit to having to crank the engine a bit after a long layup: The bearings might dry up a bit and a crank or two would help lube them up before the start.
Terry
Life is good.
1970 CB750
1975 GL1000
1999 GL1500 SE
2002 VT750
tlbranth is offline
post #27 of 29 (permalink) Old 01-30-2018, 11:23 AM
Screw's Avatar
Intake, Compression, Power, Exhaust, what do I know Im a Diesel mechanic, lol. Im wondering if fuel is leaking through to the cylinders, but less likely on the center stand. Could just check for spark after sitting that would tell you for sure if its fuel. One shot of starting fluid in the carb box before cranking would tell you if its fuel probably too. I just really dont know, deep down I think the switch.
Screw is offline
post #28 of 29 (permalink) Old 01-30-2018, 12:36 PM
Nope, it's better if the engine starts right away and spins the oil pump faster to get the oil pressure up & sling it around. A turn is a turn on a dry bearing if it's cranking or running doesn't matter.
post #29 of 29 (permalink) Old 01-30-2018, 12:41 PM
Originally Posted by Sticks View Post
The cruise light comes on when I turn on the key and if I push the cruise button. .
The above statement proves it is NOT the switch.
does any know what this would be worth PAF1047 Miscellaneous Forum 4 01-25-2011 09:11 AM
Is it worth it ??? frankenpak Goldwing Technical Forum 9 07-11-2009 10:52 PM
Is it worth it? UbarW General Motorcycle Discussion Forum 8 04-13-2009 07:23 PM
is it worth it? For Sale/Wanted Forum 12 03-11-2009 11:46 AM
Is it worth it? steve604 General Motorcycle Discussion Forum 11 09-04-2007 11:46 AM
