1200 SEI wobble around curves - Steve Saunders Goldwing Forums
 2Likes
post #1 of 20 (permalink) Old 01-26-2018, 08:07 AM Thread Starter
EAGLECRY24's Avatar
Year: 1986
Model: GL1200 SEi
My 86 SEI seems to wobble around curves. The tires are fairly new and the pressures are right. The speeds are around 70-80 mph. I tried weight shifting different ways (leaning forward, aft, and off the seat). The roads are smooth interstates with 3 to 4 lanes. I donít remember my 87A doing this. Any thoughts? Oh yea, the head bearings are new (less than a year).
I got rid of my alluminum wings and picked up a Goldwing. Here to live once, die once and give Glory to God while doing it.
Budd
87 GL1200A
83 Kawi 750K (Twin)
78 Yami XS750 Special (Triple Special)
EAGLECRY24 is offline
post #2 of 20 (permalink) Old 01-26-2018, 09:35 AM
What kind of tires and what pressure?
How much air are you running in the shocks and do you have Progressive springs?
post #3 of 20 (permalink) Old 01-26-2018, 09:52 AM
Swing arm bearings and tube not rusted?
redwing52 is offline
post #4 of 20 (permalink) Old 01-26-2018, 01:26 PM Thread Starter
EAGLECRY24's Avatar
Year: 1986
Model: GL1200 SEi
32 psi on Michelin commander ii.
Swing arm is not rusted. Bearing?... Iíll have to check it out more.
Budd
87 GL1200A
83 Kawi 750K (Twin)
post #5 of 20 (permalink) Old 01-26-2018, 01:28 PM Thread Starter
EAGLECRY24's Avatar
Year: 1986
Model: GL1200 SEi
Progressive springs and about 10psi in the front and about 50psi in the rear.
Budd
87 GL1200A
83 Kawi 750K (Twin)
post #6 of 20 (permalink) Old 01-26-2018, 01:36 PM
Rednaxs60's Avatar
I have Michelin Commander II on my '85 LTD - keep front/rear at 40 PSI. Works well. Check the balance on the tires. I have used Counter Act balancing beads, but now use and prefer Ride-On Sealant and Balance Formula.
Good luck.
Ernest
Rednaxs60 is offline
post #7 of 20 (permalink) Old 01-26-2018, 01:51 PM
Yeah, my first thought was flat tires, and you have confirmed that.
Pump 'em up and try again.
post #8 of 20 (permalink) Old 01-28-2018, 10:56 AM Thread Starter
EAGLECRY24's Avatar
Year: 1986
Model: GL1200 SEi
Just checked tire air pressure. They are around 42psi. I thought it was 32.
Budd
87 GL1200A
83 Kawi 750K (Twin)
post #9 of 20 (permalink) Old 01-28-2018, 12:21 PM
Average Goldwing Rider
JamesPal's Avatar
Year: 1972, 1981, 1985
Make: CB450, GL1100, GL1200I
Budd,
My '85 does this too. It also has the Commander II tires. I like Dennis' advice to stiffen up the shocks. Something I will work on once the riding season comes around.
Jim Palmer
Current rides:
\'85 GL1200I Garage Find
\'81 GL1100 Std
\'72 CB450K5
My \'81 Restoration:
JamesPal is offline
post #10 of 20 (permalink) Old 01-28-2018, 07:41 PM
Rednaxs60's Avatar
When I bought my '85 LTD just over two years ago, one of the first upgrades I did was the suspension. After 30 odd years the suspension needs work even if it is replacing worn/used/weak parts such as the springs. Suspension is a key element in keeping the tires firmly planted on the road. Options are in order of personal preference: Traxxion, Race Tech, Progressive, OEM (if available). Weak/soft suspension also impacts on tire performance and longevity.
Did the same with my '08 1800 as well - Traxxion suspension installed.
Just some thoughts.
Cheers
Ernest
Is it me or the overall suspension? CURVES Metal_Bob General Motorcycle Discussion Forum 21 06-30-2014 11:22 PM
1200 interstate wobble monkeytrucker Goldwing Technical Forum 2 03-19-2012 12:35 PM
Fairing lowers from a 1200 SEI on a 1200 Interstate BeachCityCustoms Goldwing Technical Forum 7 09-26-2010 09:24 AM
A GL1200 Sei front end wobble story coachk64 Goldwing Technical Forum 4 09-02-2009 10:10 AM
GL 1200 Death Wobble winged83 Goldwing Technical Forum 4 12-30-2007 11:21 AM
