5 to 4 wire converter. - Steve Saunders Goldwing Forums
  • 1 Post By Bellboy40
post #1 of 10 (permalink) Old 01-27-2018, 10:15 AM Thread Starter
GEason's Avatar
Year: 2015
Model: Goldwing 1800
Good evening to all. I have an issue with trailer wiring on my 2015 Goldwing. I have installed a trailer hitch and the plug and play wiring harness for the Goldwing. Checking the wiring with a test light, all is good coming out of the 5 wires. I bought a 5 to 4 wire converter and hook it up. I have tail lights out of the plug, when I activate brakes I get a good test. Now here is the kicker, I activate my left turn signal and get output on the left and right. When I activate the right turn signal, again I get signal out of both. Any ideas?
GEason is offline
post #2 of 10 (permalink) Old 01-27-2018, 10:36 AM
My guess is that the Ground is not good...
be sure that white wire is attached to a good solid, clean, ground surface.
post #3 of 10 (permalink) Old 01-27-2018, 11:02 AM
Did you get the results by hooking up the trailer and watching the lights or were you checking with a test light? I ask as the problem might exist in the trailer????
redwing52 is online now
post #4 of 10 (permalink) Old 01-27-2018, 11:22 AM Thread Starter
GEason's Avatar
Year: 2015
I just finished checking the ground and it has a good ground.
GEason is offline
post #5 of 10 (permalink) Old 01-27-2018, 11:25 AM Thread Starter
GEason's Avatar
Year: 2015
I used a test light out of the flat 4 connector. The trailer lights work fine on dads bike. For some reason when I turn on either turn signal both flash coming out of the converter
GEason is offline
post #6 of 10 (permalink) Old 01-27-2018, 05:51 PM
Bellboy40's Avatar
Year: 2000 & 1994
Have you connected the plug to the trailer and see if it works like it should?
Bike...and Dennis likes this.
Larry
-- Albert Einstein
Bellboy40 is offline
post #7 of 10 (permalink) Old 01-28-2018, 07:40 AM
wingpilot96's Avatar
Model: 08 1800HPNA
Personally I found it better to stay with the 5 wire system. I also had the issue of "ghost flashing", where when I would use the left turn signal, the right would also flash but it was less dim. I tried different 5to4 converters and also made a better ground connection to no avail. Since reverting back to a 5 wire..no issues!
2008 GL1800 HPNA - 18,500+ miles
1988 Bunkhouse Camper
wingpilot96 is offline
post #8 of 10 (permalink) Old 01-28-2018, 07:50 AM
Ghost Rider 2's Avatar
I would ask if you are using a standard 5/4 converter or a powered one that has a separate lead straight to battery. They cost twice as much but they work. Have seen several problems with standard non powered converters.
1980 GL1100 Standard/ with Vetter upgrades
2005 Honda Shadow Aero 750 wife (Better Half)
2002 Honda 1800 trike wife (better half)
2003 Honda 1800 everyday bike 95,000+
2014 GL1800 called midnight riding just a little it waiting for me to retire. (soon)
Ghost Rider 2 is offline
post #9 of 10 (permalink) Old 01-28-2018, 09:08 AM
We have seen several problems with those isolators also.
post #10 of 10 (permalink) Old 01-28-2018, 12:20 PM
I am going to wade back in.
Get rid of the converters period.
They are not necessary, IF, you will add one wire to the trailer and install separate Brake Lights.
That is far easier to do than messing with the bike, and it is one heck of a lot more stable.
That is what I had to do, after finding that the "powered isolator" and the 5-4 converter both burned up on my bike.
Why" because every time I stop beside the road, I use the 4-way flashers and converters and Emergency Flashing lights don't work well, they burn up in a heart beat.
Now, I have full lighting just like it is supposed to be, Straight through to the trailer's equivalent light.
Turn to same side Turn light.
Brake to Brake Lights
Running to Running Lights.
Ground to Light wire grounds/frame of trailer.
Look at this video, no convertors, no isolator.
Another trailer wiring question... 5-4 wire converter issue??? SOLVED!!! pwhoever Trikes, Trailers and Sidecars 14 11-07-2013 10:29 AM
Rudy's 4 to 5 wire Trailer Wiring Converter Rudy General Motorcycle Discussion Forum 9 07-11-2012 06:48 AM
5 wire - 4 wire Taillight Converter BlueWinger Goldwing Technical Forum 9 10-10-2010 01:04 PM
5 wire to 4 wire Converter Diagram? William_86 Goldwing Technical Forum 10 07-06-2010 11:25 AM
wire up to a 4 wire trailer from 6 wire plug! vv0350 General Motorcycle Discussion Forum 3 04-10-2007 07:59 PM
