Clutch bleeding - Steve Saunders Goldwing Forums
post #1 of 14 (permalink) Old 02-18-2018, 06:09 PM Thread Starter
big PIA
MysticFour's Avatar
Clutch bleeding
Started my bike up today to bring up to garage at in laws. Clutch needs bled I believe, Had to pull all the way in to release, was fine when parked. By time I got here I could no longer get it into neutral while running . Any tips to make bleeding it easier? Keep in mind I have never had covers off this bike as of yet. Getting ready to do my winter maintenance for 1st time. Adding rear speakers and air shocks
MysticFour is offline
post #2 of 14 (permalink) Old 02-18-2018, 06:15 PM
If the brass bushing in the lever has worn through it will do that and not give much or any warning.
Ken Bergen is online now
post #3 of 14 (permalink) Old 02-18-2018, 06:16 PM Thread Starter
big PIA
MysticFour's Avatar
Darn it, I put the post in wrong place, can someone move thing back out of altered induction
post #4 of 14 (permalink) Old 02-18-2018, 06:17 PM Thread Starter
big PIA
MysticFour's Avatar
I forgot about that, I will hafta look at that, would make things so much easier, best was to look at it? Remove lever or?
post #5 of 14 (permalink) Old 02-18-2018, 06:24 PM
Yep.
The clutch on a 1500 is pretty easy to bleed, the bleeder is just below the alternator and easy to get to. You will probably have to bleed it at the banjo bolt on the master if the fluid has gotten too low.
post #6 of 14 (permalink) Old 02-18-2018, 06:29 PM Thread Starter
big PIA
MysticFour's Avatar
It will be tomorrow af this point. Haven't got any JIS screwdrivers yet, don't want to mess up the screws on this bike. But I need to check all the fluids while I am at it
post #7 of 14 (permalink) Old 02-18-2018, 07:08 PM
If you have the original tool kit you have the correct screwdriver.
post #8 of 14 (permalink) Old 02-18-2018, 07:10 PM Thread Starter
big PIA
MysticFour's Avatar
Actually the original took kit is still in the saddle bag bungee down. Forgot about that
post #9 of 14 (permalink) Old 02-18-2018, 08:32 PM
gumbyred's Avatar
Model: 2006 Level 2 Gold Wing
I would also bleed/change brake fluid front and rear if you don`t know the history of that maintenence. Not just check fluid level.
gumbyred
gumbyred is offline
post #10 of 14 (permalink) Old 02-19-2018, 07:21 PM Thread Starter
big PIA
MysticFour's Avatar
Found out why clutch mot right. Need to check for leaks now. Still no time to do this but decided to check fluid at least tonight.
File Type: jpg 15190895661027425515783444399447_1519089592009.jpg (91.3 KB, 34 views)
BLEEDING THE CLUTCH cajundude62e Goldwing Technical Forum 17 07-04-2009 12:04 PM
bleeding clutch jeffo Goldwing Technical Forum 5 03-06-2009 11:24 PM
Bleeding Clutch 396FISH Goldwing Technical Forum 11 12-02-2008 05:05 PM
bleeding clutch schpeener Goldwing Technical Forum 2 05-20-2007 07:21 PM
clutch bleeding EDDIE W Goldwing Technical Forum 28 01-11-2007 09:59 PM
