Retired and Re-tired? - Page 2 - Steve Saunders Goldwing Forums
 29Likes
post #11 of 92 (permalink) Old 03-03-2018, 09:14 PM Thread Starter
The Counteract beads came today. Package was kind of damaged and some of the sand had leaked out.
I was expecting BBs and got sand. What's up with that? Have I gotten the wrong stuff?
post #12 of 92 (permalink) Old 03-03-2018, 09:20 PM
I would expect very fine granules that look exactly like white sand.
That is what Dyna Beads looks like.
maybe .010 inch diameter at most.
probably more like 0.005" diameter.
post #13 of 92 (permalink) Old 03-03-2018, 09:26 PM
The destructions say that you can pour them through the valve stem so tiny and round would be right, tiny and angular/sharp would be wrong.
Ken Bergen is online now
post #14 of 92 (permalink) Old 03-03-2018, 09:30 PM Thread Starter
Then I must have gotten the right stuff. Another question; is using their valve required? They only supplied one.
post #15 of 92 (permalink) Old 03-03-2018, 10:20 PM
Model: 1993 GL 1500
Dennis, I just had a new rear tire installed at the dealer. He sprayed the tire with Honda Polish to mount the tire. I asked him about it and he said that stuff was good for everything. LOL
Jerry Burns is offline
post #16 of 92 (permalink) Old 03-04-2018, 12:37 AM
Just Winging It
JeffMayfield's Avatar
Year: 1986
Make: GL1200I
Model: GL1200I 1986
The free valves I got with my balance bead order would not fit the oem stem.
Over the past 10,000 miles I have never had a bead stuck in the valve.
I think it is because I always check the pressure with the stem pointing down or up depending on how you look at it........
JeffMayfield is offline
post #17 of 92 (permalink) Old 03-04-2018, 01:24 AM
yup,
I always rotate the tires to the valve stem down position....
that is sort of necessary anyway, I can't reach a valve stem when it at the topmost position
a small puff of air into the tire will blow any beads back into the tire if you are concerned.
personally, I have never bothered, and never had a valve stem jam.
post #18 of 92 (permalink) Old 03-04-2018, 01:28 AM Thread Starter
That may be a problem. I check the rear at the 7 or 8 o-clock position and the front at 2 or 3 o-clock.
post #19 of 92 (permalink) Old 03-04-2018, 01:34 AM
I still don't think it is going to make any difference Dennis,
when the tire is not rotating, all of the beads fall towards the center of the earth anyway.
Centripetal force is what makes them do their tricky work.
post #20 of 92 (permalink) Old 03-04-2018, 10:10 AM
Year: 97
Model: GL1500 SE
I didn't get valves with mine. Have not had a problem either. The only tricky thing was getting the beads in. Had to use an electric engraver to vibrate the angle stems so the Dyna beads would flow.
I really think the beads mostly spread out and stick to the tire. The tire I pulled off had them and they were mostly all stuck to the tire.
Sent from my SM-G955U using Tapatalk
97 GL1500 SE
brian.peters is offline
Retired Hodgy Fun Forum 5 04-30-2012 04:56 AM
What do you old folks do now that you're retired? AZgl1800 Fun Forum 20 09-10-2008 08:56 AM
RETIRED? Cyote61 Miscellaneous Forum 21 12-12-2006 03:06 PM
Retired GLester Fun Forum 2 06-15-2006 10:12 PM
Retired GLester Fun Forum 10 03-26-2006 10:03 PM
