Gold wing Interstate starter not engaging - Page 2 - Steve Saunders Goldwing Forums
 6Likes
post #11 of 44 (permalink) Old 03-09-2018, 07:36 PM
Originally Posted by lcorne1972 View Post
Fill it down in the grooves so the starter will line up evenly but I used the old sprocket instead so the starter lines up
Better
Sent from my Z981 using Tapatalk
I find it amazing that we both speak English and I still have no idea what you did.
Ken Bergen is online now
post #12 of 44 (permalink) Old 03-09-2018, 07:37 PM
It just sounds like your "modification" failed the first time you used it.
Do you still have the old starter. Lots of folks here have pretty good luck refreshing the OEM units.
post #13 of 44 (permalink) Old 03-09-2018, 08:14 PM
Alaskan Explorer on a Valk
Wilcoy02's Avatar
Year: 1983
Model: GL1100
Bench test both starters to see if they still spin.
If they do then do as described above. This will help clean out the starter assem in the engine. Use a lighter weight oil also.
Above meant to see if the sprocket is still in the chain.
Keep us posted
Wilcoy02 is offline
post #14 of 44 (permalink) Old 03-09-2018, 08:23 PM Thread Starter
Year: 1980
Model: GL1100 Interstate
Keep us posted
The sprocket is still in the chain and I did a bench test the starter spins but just not turning the engine
lcorne1972 is offline
post #15 of 44 (permalink) Old 03-09-2018, 08:26 PM
Does the stater turn the sprocket that you modified?
post #16 of 44 (permalink) Old 03-09-2018, 08:27 PM Thread Starter
Year: 1980
I can't tell unless I take out the engine from the frame
post #17 of 44 (permalink) Old 03-09-2018, 08:39 PM
So you modified the sprocket while it was still in the engine?
post #18 of 44 (permalink) Old 03-09-2018, 08:41 PM Thread Starter
Year: 1980
No haha I modified the new sprocket to fit in evenly in the chain it turned over once then it just spins like it's not catching
post #19 of 44 (permalink) Old 03-09-2018, 10:15 PM
Wilcoy02's Avatar
Year: 1983
Model: GL1100
I had this problem in Oct. Your engine needs a cleaning with sea foam and a lighter oil that is made for motorcycles--NOT car oil.
This cleaned my starter assembly and the lighter oil made it work.
Wilcoy02 is offline
post #20 of 44 (permalink) Old 03-10-2018, 08:06 AM
RB
RB's Avatar
Send a message via AIM to RB
What they are trying to tell is your starter clutch is not engaging, the starter is spinning and the chain is rotating??? correct, but the engine doesn't move. The starter clutch has rollers and springs if they are stuck the engine doesn't engage. Three ways to try and fix it..pull the engine and clean out /replace the rolls and springs, thin out your oil with sea foam or MMO run the bike easy for a 100 miles or so and hope that that washes the rollers and springs and loosens them up, third drill a hole in the case in exactly the right spot and squirt cleaner right at the three rollers. There are sSeveral are several threads that go into great detail on this problem..do a search but here are some pics..
1976 GL1000 RED rebuilt SOLD
1975 sold
1978 sold
1981 sold
1982 sold
1982 sold
1983 A sold
1997 1500 SE SOLD
1999 1500 SE SOLD
1998 1500 SE..RIDING
FAIR WINDS,
RB
RB is offline
Starter not engaging. alvaltar Goldwing Technical Forum 17 11-14-2017 05:30 PM
83 gw starter not engaging gumby Goldwing Technical Forum 3 03-02-2014 10:07 AM
86 GL1200 Gold Wing Interstate bigswede Goldwing Technical Forum 3 11-04-2010 11:35 AM
86 Gold Wing 1200 Interstate bigswede Goldwing Technical Forum 11 06-10-2010 11:31 AM
Starter Relay on 88 1500 Gold Wing Springwater Goldwing Technical Forum 1 05-04-2009 11:48 AM
