Confused ATF for fork oil - Page 3 - Steve Saunders Goldwing Forums
 19Likes
post #21 of 25 (permalink) Old 04-07-2018, 08:44 AM
Ekvh1's Avatar
Year: 1977, et al
Model: Gl1000/1200
Does “fork oil” contain the detergent and anti rust additives that ATF has?
Ekvh1 is offline
post #22 of 25 (permalink) Old 04-07-2018, 09:45 AM
Isn't oil, in and of itself, a rust inhibitor?
For detergent...
...just pour an ounce, or two, of Tide in there.
DaveO430 and 75Winger like this.
post #23 of 25 (permalink) Old 04-07-2018, 12:54 PM
I doubt it, not really needed.
post #24 of 25 (permalink) Old 04-10-2018, 04:49 PM
I have looked at some dealers for various viscousties of fork oil and usually they don't have a selection. I tried 'fork oil' once and it did not seem any different than ATF, so I figured I have a gallon jug, may as well use it up. That was about 10 years or more ago. ATF is still what I use even in my GL 1800.
limpy45 is offline
post #25 of 25 (permalink) Old 05-21-2018, 12:44 AM
gt750's Avatar
Year: 2006
Model: GL1800A
There's nothing wrong with using ATF. The reason many people use a designated Fork Oil is to be able to set and/or adjust the damping with weights of oil. With ATF you are just guessing. If you're the type of guy who doesn't need a torque wrench to tighten fasteners, you can also use your calibrated elbow to shake the bottle of ATF and determine the viscosity!
I was so happy to be on my 'Wing that I patted her tank and was laughing in my helmet!
gt750 is offline
can i use ATF for fork oil? Mike Myers Goldwing Technical Forum 23 05-27-2015 10:38 AM
Using atf for GL1500 fork oil gnscott Goldwing Technical Forum 6 09-25-2013 12:15 PM
ATF, 10wt, 15wt, 10-15wt mix fork oil for gl1500 EDIT SmartBiker Goldwing Technical Forum 9 01-02-2013 03:56 PM
Fork Oil - Is any type of ATF OK? mdbauer1962 Goldwing Technical Forum 10 05-07-2009 02:55 PM
Fork seals, dustcaps, fork oil ,or ATF GL1200 A muaymendez1 Goldwing Technical Forum 4 08-25-2008 06:49 AM
