"the Hunley", or pidjones needed a project - Page 7 - Steve Saunders Goldwing Forums
 39Likes
post #61 of 64 (permalink) Old 06-26-2019, 08:33 PM
Originally Posted by Pure Texas View Post
Goldwing motors donít run worth a crap with open headers,they need back pressure.
I think he covered that in the big post:
I have a pretty good muffler set and hangers for it from a previous build.
pidjones likes this.
post #62 of 64 (permalink) Old 06-27-2019, 04:27 PM Thread Starter
pidjones's Avatar
Model: '06 GL1800, '78 GL1000 with '75 motor
Finished dismantling the "parts" '79 that I brought home several weeks ago. You know a GL1000 is just a lump if you have to use crowbars, oak 2x's and a sledge hammer to split the cases! Surprisingly, the main and rod bearings looked good - no copper showing so I pulled the mains and labeled them including labeling the box with the code from the engine cases. Crank looked Ok. Gears rusty so they will be tossed along with the cases.
"Love 'em all... Let God sort 'em out!"
'52 wife - '69 daughter - '83 daughter
ex '86 SE-i
ex '77 GL1000
pidjones is offline
post #63 of 64 (permalink) Old 07-14-2019, 07:52 AM Thread Starter
pidjones's Avatar
Been having a lot of fun taking the Hunley to nearby shows this year. Yesterday, we took her to the "Moonshiner's Run" car show in Stearns, Kentucky. Great turn-out of machines and people (check their Facebook page). I always like getting snapshots of the pinup girls on the bike.
BTW, the blonde is headed for Afganistan in 2 weeks for 9 months.
AZgl1800 and lionelgo50 like this.
ex '86 SE-i
ex '77 GL1000
pidjones is offline
post #64 of 64 (permalink) Old 07-30-2019, 09:15 PM Thread Starter
pidjones's Avatar
I finally pulled the '79 out of the family room side of the basement and into the garage. Took some photos as I swapped the bikes around. Headlight was removed to permit removal of the Vetter umbilical and will stay off until I can heal all of the wounds caused by the Scotch-Loks. After getting it in the garage, I pulled the cam belt covers and installed new timing belts. The old ones were stiff and the vendor info worn off the outside, so they were definitely due. Pulled the plugs and hooked up the battery (I had charged and stored it in a plastic battery box). Checked compression, and Yahoo! all 180 +/- 5 psi! The bottom of the engine is covered with oil and there is no obvious source, so I'll clean it well and watch. Although, the '77 that I had back in 2004 had the same oil coverage and it turned out to be from leaky fork seals. The cap over the rotor bolt was jammed and rounded so I had to chisel it off but luckily I had a spare from the junker engine. I think tomorrow I might just hook up the external fuel cell and see if it will fire.
ex '86 SE-i
ex '77 GL1000
pidjones is offline
My "Old School" trike project Mr. Barry Trikes, Trailers and Sidecars 29 05-16-2018 09:25 PM
Goldwing Project "Barn Bike" Traverse New Members Introduction Forum 16 07-06-2014 04:02 PM
'78 GL1000 "Bobber" project For Sale $700 OBO rOmiLaYu For Sale/Wanted Forum 16 03-26-2013 08:28 PM
1980 GL1100 "restoration" project Goldwing Technical Forum 12 08-19-2008 06:06 PM
