1500 No start - Page 5 - Steve Saunders Goldwing Forums
 14Likes
post #41 of 48 (permalink) Old 05-06-2018, 06:56 PM Thread Starter
Year: 1983
Make: Honda Goldwing
Model: GL1100 Interstate
I did the crossing of terminal with screwdriver and with a wire from positive terminal to directly to the stud on the right side of relay
A. I got power to the fuses and the starter did work. I just replaced tha relay last year. so I guess I need to replace it again as there is no clicking that I can feel when crossing terminals. Fuse is also good. When I cross the terminal I do get power to relay B also and it clicks I can feel it.
legend 63 is offline
post #42 of 48 (permalink) Old 05-06-2018, 10:14 PM
A. I got power to the fuses and the starter did work. .
That looks to me like you have the relay connected backward.
post #43 of 48 (permalink) Old 05-07-2018, 01:37 AM
Relay "A" will not click when you jump it as described. That is normal. Before you condemn the relay "A" you might want to try this. Do tests #1 and #2 below.
Test #1: With the key and kill switch on hook the test light as illustrated below. Yes that funny looking thing is a test light. With the alligator clamp grounded (negative battery) find the little Yellow wire with the red (yel/rd) stripe on relay "A" and probe as the illustration shows. Each time you push the start button the test light must light. Does it? If it lights go to test #2.
Test #2: Key and kill switch on. Hook the test light as illustrated below. Alligator clamp on battery positive. ( Battery +) With the bike in neutral (neutral light on) probe the small Brown wire with the red stripe on relay "A".(brnl/rd) The test light should light at all times in neutral. (no need to push start button, Will make the test invalid if you push the start button) If not raise the side stand and pull in the clutch. The light should light with the clutch pulled in only. (light goes out with clutch out) Does the light come on for any/all of the tests? Check back with us with results.
legend 63 likes this.
redwing52 is offline
post #44 of 48 (permalink) Old 05-07-2018, 08:32 PM Thread Starter
Year: 1983
so why would it have worked before??????
post #45 of 48 (permalink) Old 05-07-2018, 10:15 PM
I'm just going by what you posted. You haven't done much as far as doing what people have suggested to diagnose the problem, just jumping around here and there and jumping to conclusions that turn out wrong.
post #46 of 48 (permalink) Old 05-11-2018, 05:53 AM
corkya's Avatar
Model: 1999 GL1500 Aspencade
Originally Posted by DBohrer View Post
Larry, There is a wiring diagram for the starting circuit at post # 25 and post # 30.
Look at them...........!!!!!
Larry, the only time these knowledgeable guys have not quikcly solved my problems on both of my bikes was when I didn't do EXACTLY what they suggested! There a number go great guys here that, by personal experience, know the precise sequence required to eliminate a number of variables in the troubleshoot process.
corkya is offline
post #47 of 48 (permalink) Old 05-11-2018, 03:28 PM Thread Starter
Year: 1983
I realize they are very knowledgeable and informative plus trying to help me solve the issue. I have been working 12 + a day so not much time to do testing. I will be post back hopefully tonight results.
post #48 of 48 (permalink) Old 05-27-2018, 09:59 PM Thread Starter
Year: 1983
Sorry it took so long to reply but it is fixed.
Did test that were suggested then replaced Relay A and problem solved. Bike is back together and going down the road.
Thanks for all the help much apprfeciated
Larry
redwing52 likes this.
GL 1500 98 No Start Dandy Dave Goldwing Technical Forum 1 04-06-2015 01:35 PM
88' 1500 no start Slopokn Goldwing Technical Forum 7 11-30-2014 09:52 PM
1500 no start wilf Goldwing Technical Forum 8 10-03-2012 07:38 PM
GL-1500 - no start - rgbeard Goldwing Technical Forum 17 06-02-2011 09:34 PM
1500 will not start gunslinger Goldwing Technical Forum 9 11-22-2010 11:09 AM
