No Neutral light No starting - Page 3 - Steve Saunders Goldwing Forums
 7Likes
post #21 of 32 (permalink) Old 04-22-2018, 10:09 AM Thread Starter
DrifterTex's Avatar
Year: 1998
Wink
Yes, I have . I keep a maintainer on it. It's good.
Originally Posted by Power Guy View Post
When checking the battery, you should get 14v. (That is ideal). Your wing might torn over at 12v. But anything under that will most likely just not enough to roll it over.
Have you tried starting it with the charger on the battery? I may be going down the wrong path here, but it’s worth giving it a shot.
Texas Winged Horny Toads
NRA Life
PGR # 183546
Boy Scouts of America
Darkside # 1114
Iron Butt Association #45601
1998 GL 1500 SE 81,000 miles
2012 Suzuki Burgman Executive 650
2014 Suzuki V-Strom 1000
2009 KLR (gone)
2006 Suzuki Burgman 26,000 miles (gone)
DrifterTex is offline
post #22 of 32 (permalink) Old 04-22-2018, 11:19 AM
Power Guy's Avatar
Model: Aspencade 1500
Ok as I said,I may be way off track here. Hope you find the issue so I can learn as well.
Power Guy is offline
post #23 of 32 (permalink) Old 04-22-2018, 12:51 PM
The revers diode assy on the frame behind the right saddle bag has a tendency to come unplugged, I think you can reach it with the seat removed.
DrifterTex likes this.
post #24 of 32 (permalink) Old 04-27-2018, 10:26 AM Thread Starter
DrifterTex's Avatar
Year: 1998
A HUGE thank you to DBohrer for helping me diagnose my issue. It was the reverse lever switch. He helped me check several things which lead to the switch. I got to the old one and started playing with the plunger. Sometimes the light would come on, sometimes it would not. Ordered a new one and ready to install. Thank you all, for the help and suggestions. Gave me several things to try and to rule out things.
And again, Thank you
DBohrer.
NRA Life
PGR # 183546
Darkside # 1114
2009 KLR (gone)
post #25 of 32 (permalink) Old 04-22-2019, 03:58 PM
markfox's Avatar
Year: 1996
Model: GL 1500 SE
O.M.G! Thanks to this forum I have followed what has been said about the "no neutral light and won't start" tips and after a couple of days faffing around it's back to normal!! Reverse lever removed and a good spraying behind with WD-40 and it's good to go. Thanks to everyone who has had an input into this problem I am so,so grateful. πŸ‘
flylow likes this.
markfox is offline
post #26 of 32 (permalink) Old 04-22-2019, 04:30 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
Hey Mr. Fox, You might like to read the attached document. Its been lurking around on my computer for some time....!!
DBohrer is online now
post #27 of 32 (permalink) Old 04-22-2019, 04:45 PM
markfox's Avatar
Year: 1996
Model: GL 1500 SE
Thankyou, but for some reason it won't open for me but I only have my phone and no computer so maybe that's why. - spanners 1- techstuff 0
Sent from my EML-L29 using Tapatalk
markfox is offline
post #28 of 32 (permalink) Old 04-26-2019, 06:39 AM
DBohrer's Avatar
For anyone following this "Old" thread, I sent Mr. Fox the file via email...and.... he has it ok.....!!
post #29 of 32 (permalink) Old 04-26-2019, 07:10 AM
markfox's Avatar
Year: 1996
Model: GL 1500 SE
Thankyou for the file. I am very much obliged.
markfox is offline
post #30 of 32 (permalink) Old 04-26-2019, 07:15 AM
Bellboy40's Avatar
Year: 2000 & 1994
It is kind of a wonder that the neutral light works as well as it does. The wiring for the light goes through 9 connectors before it is able to light. Plus a couple of switches have to work right.
DBohrer likes this.
Larry
-- Albert Einstein
Bellboy40 is offline
Neutral Light/Starting Issue DBohrer Goldwing Technical Forum 8 10-18-2016 11:32 AM
Neutral light/starting issues lonnie.p Goldwing Technical Forum 19 11-10-2014 08:18 AM
Neutral/reverse light starting problem Cliff Goldwing Technical Forum 7 02-27-2011 12:24 PM
82 Aspencade Temp Gauge, Neutral Light & Tail Light not working BNC173 Goldwing Technical Forum 8 03-22-2009 09:59 PM
Neutral light stays on dimly, brighter in neutral. mag Goldwing Technical Forum 17 01-01-2007 12:41 PM
