No Neutral light No starting - Page 4 - Steve Saunders Goldwing Forums
 7Likes
post #31 of 32 (permalink) Old 05-04-2019, 12:44 PM
tlbranth's Avatar
Year: 1999, 1975
Model: GL1500SE GL1000
Been riding Hondas since 1967. Last year on a trip far from home, stopped for a break, bike did what you describe (except for the neutral light). After 2 hours of disassembly, frantic phone calls etc., noticed the kill button was on. Now that's the first thing I check.
I'm not sure where your neutral switch is but if you can pull the wire and ground it, that'll tell you if the switch is bad.
Another time the symptoms were exactly as you described, again far from home. Push started it. The problem was in the reverse setup. Don't remember the exact cause but I adjusted the cables, checked the switches....OK now.
Good luck. Tell us the outcome eh?
Terry
Don't own a Vanagon.
Don't work at Boeing.
Life is good.
1970 CB750
1975 GL1000
1999 GL1500 SE
2002 VT750
tlbranth is offline
post #32 of 32 (permalink) Old 05-04-2019, 01:13 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
The neutral switch is right above the "Oil Dip Stick"...!!
The reverse cables move an arm that makes the "neutral switch" send a ground (or not) to the starting circuit.....!!
7. The reverse “neutral” switch provides a ground for the following:
a. To trigger the reverse relay switch (which provides ground to trigger the starter relay A)
b. To trigger the starter relay B.
c. The reverse control unit.
8. If the reverse “neutral” switch is good, then check the reverse cables for proper adjustment and the reverse arm alignment (right side of the engine).
DBohrer is offline
Neutral Light/Starting Issue DBohrer Goldwing Technical Forum 8 10-18-2016 11:32 AM
Neutral light/starting issues lonnie.p Goldwing Technical Forum 19 11-10-2014 08:18 AM
Neutral/reverse light starting problem Cliff Goldwing Technical Forum 7 02-27-2011 12:24 PM
82 Aspencade Temp Gauge, Neutral Light & Tail Light not working BNC173 Goldwing Technical Forum 8 03-22-2009 09:59 PM
Neutral light stays on dimly, brighter in neutral. mag Goldwing Technical Forum 17 01-01-2007 12:41 PM
