Brake lights - Steve Saunders Goldwing Forums
post #1 of 11 (permalink) Old 05-06-2018, 12:19 PM Thread Starter
1980ratwing's Avatar
Year: 1980
Model: GL1100 Standard
Brake lights
I have a 1980 gl1100. My stock brake lights and running lights stopped working a bit ago, I've tried new bulbs and cleaned out the socket. It didn't work. So I got a new brake light that includes the running lights and turn signals. It's a license plate frame. But I still cant get the brake lights or running lights to work. And now my turn signals stay solid. Need some help!!
1980ratwing is offline
post #2 of 11 (permalink) Old 05-06-2018, 12:22 PM
Did you check the fuses? And not just look at them. They have a bad habit of breaking loose at the ends and the clips get corroded and loose. And your turn signals are not going to work with LEDs unless you change the flasher.
post #3 of 11 (permalink) Old 05-06-2018, 12:23 PM Thread Starter
Year: 1980
I've been checking them. The ones under the false tank, I've changed a few. But I didn't look too closely. I'll check them now
post #4 of 11 (permalink) Old 05-06-2018, 12:24 PM Thread Starter
Year: 1980
How do I change the flasher? The new lights are LEDs
post #5 of 11 (permalink) Old 05-06-2018, 04:06 PM
Go to your favorite parts store and get an electronic flasher, a 2 prong one. on the left side of your frame (maybe it's still there) is the flasher, a round aluminum can. Remove it and connect the grey and white/green to the new one, leave the green wire disconnected.
post #6 of 11 (permalink) Old 05-06-2018, 04:08 PM Thread Starter
Year: 1980
Awesome, thanks. Know how to fix the brake and running light issue?
post #7 of 11 (permalink) Old 05-06-2018, 04:47 PM
OldSchool_IsCool's Avatar
Year: 1982
Model: Interstate
Do you have a voltage tester? The tail light is the brown wire and should be hot whenever the key is on. The green/yellow wire is the brake light and should be hot when the brakes are applied.
Bruce
Current Bikes:
74 CB750 K4
77 CB550 K3
82 CM250C
Past Bikes:
What?? SELL a bike??
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
PGR since 2011
OldSchool_IsCool is offline
post #8 of 11 (permalink) Old 05-06-2018, 05:00 PM Thread Starter
Year: 1980
I tried that and got nothing
post #9 of 11 (permalink) Old 05-06-2018, 05:33 PM
Alaskan Explorer on a Valk
Wilcoy02's Avatar
Year: 1983
Model: GL1100
Check your brake switch. Down by your right heel. The spring may be faulty or the switch needs moved out to let the brake lights off.
Wilcoy02 is offline
post #10 of 11 (permalink) Old 05-06-2018, 05:35 PM Thread Starter
Year: 1980
Well, I would do that, but my rear master needs replaced so I dont even have that hooked up. But it had worked without that being hooked up.
No rear lights....brake lights work tho Rocketman00 Goldwing Technical Forum 3 09-13-2015 05:26 PM
GL1200 Sei tail lights and brake lights FELIXDACAT Goldwing Technical Forum 4 06-10-2012 12:14 PM
All GL1500 lights, except headlight and brake lights, are intermittent FeHead Goldwing Technical Forum 3 08-09-2011 06:41 AM
1500 brake lights fail, normal lights fine help Cosha Goldwing Technical Forum 3 06-19-2008 02:35 PM
