What is this, 1976 gl1000 - Steve Saunders Goldwing Forums
  • 1 Post By AZgl1800
post #1 of 4 (permalink) Old 05-16-2018, 10:31 AM Thread Starter
Year: 1978
Model: GL1000
Send a message via Skype™ to torontoGL78
Right next to ignition coils/ ballast, it was very hot, removed, cleaned terminal/ connectors and put it back, still gets hot. Is it normal for it to get hot ?
It’s on a 1976 gl1000 with electronic ignition, right now fires up only on one cylinder, troubleshooting and thought of asking if this unit is causing this
Thanks
1978 GL1000 - Stock
1977CB550 - Stock
1974 CB550K - Stock
1978 CB750 - Stock
2009 HD Road King Classic
torontoGL78 is offline
post #2 of 4 (permalink) Old 05-16-2018, 10:50 AM
that is a heavy ceramic coated resistor used to drop the voltage to ignition coils sometimes,
and yes, it can get hot enough to burn your fingers.
Depends on how much current is being pulled thru it.
Used to see them a lot on 6 volt cars converted to 12 volt lights and generator/alternator.
limpy45 likes this.
What is the Forum Index?
Download it here:
post #3 of 4 (permalink) Old 05-16-2018, 04:09 PM
gipsy42's Avatar
Model: '93 GL1500 SE "Blue Angel"
Send a message via Skype™ to gipsy42
The GL1000 has a resistor in series with the coils, as you may see in the attached pict. It's standard in all 1000'.
Check if the OEM coils have been changed; if it's the case you may not need it.
Mario
And still riding...
I just regrets the things I haven't done.
gipsy42 is offline
post #4 of 4 (permalink) Old 05-17-2018, 01:25 PM
CWN
CWN's Avatar
Year: Pro 1500
Model: 43 years winging it
It's 1000 Dyna 111 resistor=.
CWN is offline
Is a 1976 GL1000 interchangeable (all parts) with a 1978 GL1000? ryster Goldwing Technical Forum 11 12-16-2010 11:11 AM
pulling gas tank on a 1976 GL1000 Lew Goldwing Technical Forum 5 03-07-2006 06:23 PM
1976 GL1000 Flanders Goldwing Technical Forum 6 02-14-2006 11:08 AM
1976 GL1000 For Sale/Wanted Forum 0 10-19-2005 04:19 PM
1976 GL1000 Goldwing Technical Forum 22 12-28-2004 12:02 PM
