Going Naked - get your mind out of the gutter. - Page 2 - Steve Saunders Goldwing Forums
post #11 of 14 (permalink) Old 05-22-2018, 04:21 PM Thread Starter
Tomhusker's Avatar
Model: 1984 GL1200
Originally Posted by Andy Cote View Post
I think that box needs to come off and all the connectors go inside the headlight bucket. Can't see the shelter well enough but if it looks like a normal tank you should be okay. Usually the installer of an aftermarket fairing would just cutoff the headlight mounting ears rather than pull the forks. Looks like you don't have them, cut or otherwise. You may want to buy some universal clamp on ones or pull the forks for factory mounts. Will need blinker mounts also.
That's kind of what I was thinking. I'm pulling the forks anyway so I can put new seals in.
Thanks.
Tomhusker is offline
post #12 of 14 (permalink) Old 05-22-2018, 04:43 PM
Andy Cote's Avatar
So long as the forks are off, as if you wanted more things to do, it would be easy to replace timing belts. Just sayin'
DARKSIDE #1500
2015 Goldwing - basic black
Ham Extra Class AC1R
Andy Cote is offline
post #13 of 14 (permalink) Old 05-22-2018, 04:46 PM Thread Starter
Tomhusker's Avatar
Model: 1984 GL1200
I don't trust myself that much. I've got a local shop that will be doing that when it's at that point.
post #14 of 14 (permalink) Old 05-23-2018, 09:34 AM
rayjoe's Avatar
He's right Tom. It ain't rocket science. Just take pictures as you disassemble it.
Good luck with what ever you decide.
Rayjoe
rayjoe is offline
I have a saying if your going to pet crocodilles expet to get bitten agnogel Miscellaneous Forum 8 10-11-2010 04:28 PM
I'm going to loose what's left of my mind. lostinflorida Fun Forum 5 06-19-2009 11:56 PM
as long as we are in the gutter.. UbarW Fun Forum 3 01-28-2009 01:03 PM
Anyone know what's going on at the Naked Godlwings site RB General Motorcycle Discussion Forum 5 08-10-2008 01:33 PM
Got my 81 naked wing going finally DaveO430 Goldwing Technical Forum 14 01-18-2008 09:32 PM
