Side cover pins - Steve Saunders Goldwing Forums
 3Likes
post #1 of 12 (permalink) Old 05-28-2018, 02:06 PM Thread Starter
Year: 1985
Model: GL1200
Side cover pins
Hi Folks
One of my side covers has a broken off pin. The previous owner tried to fix it with epoxy and it came off again, not a very good bond. On other things I've repaired ABS parts by dissolving donor ABS bits in MEK to make a paste, then forming a new base for the old part with it, usually, it reinforces the part and makes a permanent repair. would that work for this? The ABS plumbing glue we get here was never a very good substitute. it's the yellow stuff for plumbing. I see in a search on this site that it's better to use black ABS glue I've never seen for sale here.
JaVelin >X< is offline
post #2 of 12 (permalink) Old 05-28-2018, 02:28 PM
Bellboy40's Avatar
Year: 2000 & 1994
Yes, I think that would work well to get the pin reattached to the side cover.
Larry
-- Albert Einstein
Bellboy40 is offline
post #3 of 12 (permalink) Old 05-28-2018, 03:09 PM
Alaskan Explorer on a Valk
Wilcoy02's Avatar
Year: 1983
Model: GL1100
The black abs is the one to use. They quit making the good stuff (black). Make a slurry out of acetone and abs shavings.
Wilcoy02 is offline
post #4 of 12 (permalink) Old 05-28-2018, 03:40 PM
SilverDave's Avatar
Model: '85 GL1200 Aspy
Mine broke about 8 years ago ... If you still have the pin part ...
I repaired mine by first drilling a tiny tiny hole ( 1/16 ? ) in each end , and cutting a finishing nail to size ... and then the acetone slurry on the bail, and on the joint ...
The nail strengthens the joint .
While you are at it, buy 6 of the rubber grommets .. when they get old and hardened they stress the pins quite a bit upon removal
SilverDave
SilverDave is offline
post #5 of 12 (permalink) Old 05-28-2018, 05:28 PM
Model: 84&86 Interstates. 1996 1500 SE, 1978 1000
Since when did they quit making black ABS glue? I just bought a can.
purplerider is offline
post #6 of 12 (permalink) Old 05-28-2018, 05:41 PM
I will admit that I fell for the FUD (Fear Uncertainty Doubt) surrounding Yellow ABS glue.
Apparently the Yellow and the Black are the same other than the dye used for colouring.
The reason for the Yellow glue is so the plumber and building inspector can tell at a glance if a joint was missed when gluing.
Ken Bergen is online now
post #7 of 12 (permalink) Old 05-28-2018, 05:42 PM
cihilb's Avatar
Model: 2012 Pearl White
Oatey still makes it. Look up ABS cement, not glue. Cement is a little thicker, fills gaps.
cihilb is offline
post #8 of 12 (permalink) Old 05-28-2018, 11:01 PM
LarryC's Avatar
I bought some at Lowes not long ago.
Larry
84 Aspencade
79 GL1000 with VW carb
LarryC is offline
post #9 of 12 (permalink) Old 05-29-2018, 07:18 AM
DenverWinger's Avatar
I got a can of black ABS cement from ACE Hardware...
1972 CL-350 (1980-1988) sold
1977 GL1000 (2002-2006) sold
1993 GL1500 Aspencade (2017-)
1983 Trav-Lite Camper (2010-)
DenverWinger is online now
post #10 of 12 (permalink) Old 05-29-2018, 09:52 AM
Wilcoy02's Avatar
Year: 1983
Model: GL1100
Very Glad to hear it is still available.
Wilcoy02 is offline
side cover pins sprayerferlife Feedback for Hondas Goldwing Team 4 10-27-2013 07:58 PM
Side Cover Replacement Pins KAHUNAH General Motorcycle Discussion Forum 8 07-26-2011 08:25 AM
left hand side cover/battery cover and right side cover caregiver For Sale/Wanted Forum 0 09-11-2010 10:18 PM
GL1500 side cover mounting pins replace greggchill Goldwing Technical Forum 4 08-25-2009 08:50 AM
side panel male pins?? Psalmist Goldwing Technical Forum 11 01-19-2008 09:31 AM
