1985 GL1200 Runs On Starter Fluid Then Dies - Page 2 - Steve Saunders Goldwing Forums
 5Likes
post #11 of 19 (permalink) Old 12-22-2018, 07:49 PM
75Winger's Avatar
Year: 1975
Make: GL1000
So what happened??
Most of the threads I read, (especially multiple ones) seem to get to a certain point and then STOP! Please remember to do a followup, so others may know the end results. This irritates me to no end. Why is it so hard to give a small update. I am learning some things on this Forum, but get annoyed because no one takes the time to finish them.
Mount up Boys, Lets Ride!
75Winger is offline
post #12 of 19 (permalink) Old 12-22-2018, 09:04 PM
Unfortunately we get a lot of that. Most of the time it is a new member who comes on and posts a question then never returns. Not so in this case but it's still frustrating.
post #13 of 19 (permalink) Old 12-23-2018, 02:42 PM
75Winger's Avatar
Year: 1975
Make: GL1000
Yes... frustrating. Sorry I just needed to vent. Just seems when the story is nearing a conclusion, it vanishes, leaving the question, "So what happened".
Again, sorry.
75Winger is offline
post #14 of 19 (permalink) Old 12-23-2018, 05:31 PM
Average Goldwing Rider
JamesPal's Avatar
Year: 1972, 1981, 1985
Make: CB450, GL1100, GL1200I
Again, sorry.
Venting doesn't help. I will only post answers to things I have done. Sometimes I will post answers to things that I think, but a lot of times I'm wrong and it didn't help the person who is dealing with a problem. I post a lot to HondaTwins.net. If I had a dollar for every kid that joined that forum, cut the fender mount off the back of the frame, took the airbox off the carbs and couldn't figure out why the bike wouldn't run in two weeks, I could buy a new Gold Wing.
Bike...and Dennis likes this.
Jim Palmer
Current rides:
\'85 GL1200I Garage Find
\'81 GL1100 Std
\'72 CB450K5
My \'81 Restoration:
JamesPal is offline
post #15 of 19 (permalink) Old 12-23-2018, 09:06 PM
gumbyred's Avatar
Model: 2006 Level 2 Gold Wing
Not sure if ratwingger has fixed his problem, or just left the building, but on the 1800 fuel injection system there is a fuel pressure regulator valve that can go bad if the bike is allowed to sit for long periods of time. I suppose the 1200 fuel injection system could have such a valve also.
gumbyred
gumbyred is offline
post #16 of 19 (permalink) Old 12-23-2018, 09:52 PM
gumbyred
Yes the 1200 FI also has a pressure regulator but unless the OP is willing to do some testing we can't help. As far as I know we don't have an clairvoyants here.
post #17 of 19 (permalink) Old 12-23-2018, 09:55 PM
Originally Posted by ratwingger View Post
Hi guys I have a 1985 GL1200 that im working on the bike has sat for a six weeks so drained the tank put new gas in it, installed a new car fuel pump, and took out the old ratty air filter it was bad. The bike will start and run if Im spraying carb fluid in it but once I stop spraying the engine eventually sputters and stops. Can someone give me advice on what I should do in order to keep the bike running on gasonline lol instead of the starter fulid?
Now that we know, was this new pump for fuel injection? A low pressure pump for carburetors will not work for fuel injection, nor the other way around.
Just in case ratwingger comes back.
post #18 of 19 (permalink) Old 12-24-2018, 11:17 AM
75Winger's Avatar
Year: 1975
Make: GL1000
Thanks Gents... I can only think Rattwinger solved his dilemma. I dont see anymore questions.
75Winger is offline
post #19 of 19 (permalink) Old 12-24-2018, 03:45 PM
JamesPal's Avatar
There are some guys over on NGW who are taking dead GL1200 fuel injection systems and installing them on GL1100s with great results. They are using the MegaSquirt Engine Management and controls. Pretty cool stuff. I want one, with spark control...
AZgl1800 and DenverWinger like this.
Jim Palmer
Current rides:
\'81 GL1100 Std
\'72 CB450K5
JamesPal is offline
1994 GL1500 I no choke/dies twist throttle/dies tnkrtoy Goldwing Technical Forum 37 03-11-2016 03:55 PM
86 GL1200 runs fine and then cuts off sometimes Racerx Goldwing Technical Forum 6 09-20-2012 05:42 PM
GL1500 stumbles, dies, then runs great. What's up? dwlarson Goldwing Technical Forum 23 09-10-2012 10:37 PM
GL1200 dies at exact same temp everytime then backfires NVR2FAR Goldwing Technical Forum 9 08-14-2009 01:34 PM
79 GL1000 Goldwing Runs Smooth, then knocksand dies Morgan41 Goldwing Technical Forum 14 09-12-2008 10:02 AM
