Low compression - Page 2 - Steve Saunders Goldwing Forums
 13Likes
post #11 of 32 (permalink) Old 06-19-2018, 05:21 PM
Don't overlook what Dennis suggested. The engine must be warm. It can make a lot of difference. If the bike idles and runs smooth I would never waste time checking compression.
redwing52 is offline
post #12 of 32 (permalink) Old 06-19-2018, 06:56 PM
Pure Texas's Avatar
Make: Goldwing
The knock could be the alternator rubber dampers,new one are easy to install.
theRide likes this.
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is offline
post #13 of 32 (permalink) Old 06-19-2018, 09:52 PM Thread Starter
theRide's Avatar
Year: 1998
Model: Valkyrie
Itís warm and I tried WOT on the worst cylinder.
theRide is offline
post #14 of 32 (permalink) Old 06-20-2018, 06:23 AM
dingdong's Avatar
Model: 93 Gl1500 / 76 Gl1000
You should read up on the proper steps for doing a compression test. This is on a gl1000 but it is the same. http://www.randakksblog.com/engine-compression-testing/
theRide likes this.
Tom
Black 93 1500 Aspy
Yellow 76 1000
Black Cherry 04 Rune
"I've now been in 57 states? I think one left to go?" B. O.
dingdong is offline
post #15 of 32 (permalink) Old 06-20-2018, 07:29 AM
WingMan71's Avatar
Year: 2006
Model: GL1800, GL1200, GL1000
Originally Posted by theRide View Post
I went to harbor freight to pick up a leak down tester. Unfortunately the reviews are correct and the air fitting is not standard and they didnít have another that fits the threaded bore on the tool.
If you want a good quality leak-down tester, I recommend OTC tools products. I have both their leak-down tester and compression tester. Very good quality and come with all of the adapters you are likely to need.
They are available on Amazon. Here's a link to the leak-down tester.
theRide likes this.
Bob
2006 Arctic White GL1800
1987 Black/Grey GL1200 Aspencade
1976 Special Candy Maroon GL1000 LTD
U.S. Navy SWO (1967-1976)
WingMan71 is offline
post #16 of 32 (permalink) Old 07-10-2018, 05:47 PM Thread Starter
theRide's Avatar
Year: 1998
Model: Valkyrie
I finally got a chance to check compression again. This is after some ring free was added to a tank of gas. I also did the test at wide open throttle which I neglected to do last time.
I rechecked first with a closed throttle to compare apples to apples. Then with oil added. Then at WOT. Then with WOT and oil added. Then I ran out of battery.
What do you guys think?
(Leak down tester Iím waiting on from a friend so no news there yet).
I also did notice Iím in dire need of timing belts. Nothing has jumped a tooth but they have some really extreme differences between the tight spot and loose spot.
First number dry... second is with oil...third is WOT...fourth is WOT and oil
1: 118...134...162
2: 90...98...150...153
3: 105...112...176
4: 92...115...175...175
5: 112...120...170
6: 120...133...160
Previous numbers as previously posted (closed throttle)
1: 112
2: 87 (got it to 90 w penetrating oil)
3: 105
4: 97
5: 118
6: 115
Any thoughts?
Am I good to go just keep adding ring free?
Thanks all Iím slowly allowing myself to connect with this bike
theRide is offline
post #17 of 32 (permalink) Old 07-10-2018, 06:04 PM
Year: 1986
Make: honda
Model: gl1200A
you ever consider saving a perfectly good motorcycle and spending a couple hundred bucks on a real mechanic?
claydbal is offline
post #18 of 32 (permalink) Old 07-10-2018, 07:02 PM
rayjoe's Avatar
Valk
I'm afraid I have to agree with Claydbal. Valks are almost bullet proof. You do not say anything about how it runs other than it pulls strong. So what's the problem. Stop tinkering before you do more harm than good. Leave the chemicals on the shelf.
Sorry to be so blunt, but it sounds like you're looking for a problem that does not exist.
Ride it and enjoy it!!
Rayjoe
rayjoe is offline
post #19 of 32 (permalink) Old 07-10-2018, 07:56 PM Thread Starter
theRide's Avatar
Year: 1998
Model: Valkyrie
Huh?
Ken Bergen likes this.
theRide is offline
post #20 of 32 (permalink) Old 07-10-2018, 08:21 PM Thread Starter
theRide's Avatar
Year: 1998
Model: Valkyrie
Rayjoe
Adjusting valves and checking compression is hardly tinkering. That I failed to go WOT the first time around on all the cylinders was a rookie mistake but youíll also note I did try it on number 2 cylinder with little difference.
It seems the additives to oil and gas have made a real difference if you look even just at number 2 cylinder as of the last check.
I take pride in my work and have had enough nightmare experiences with ďrealĒ mechanics that opting to suss out the condition of a used bike with an unknown history seems to me quite prudent.
If it upsets some people that I ask questions perhaps they are best staying out of the tech area of the forum or better yet forums altogether. Perhaps they havenít learned anything on here and thus have nothing to share but their own vitriol. Beats me and itís honestly sad to see.
Anyway enough about that.
According to an earlier post my compression is still low. Ive often heard/read that itís more important they are all even as opposed to hitting specific numbers so long as itís not terribly low.
So with that said are there any opinions on the compression numbers Iím getting?
Thanks!
pidjones likes this.
theRide is offline
GL1200 low compression pms Goldwing Technical Forum 9 04-03-2010 09:16 AM
Can a stripped plug couse low compression RayandTracy Goldwing Technical Forum 19 10-19-2008 07:50 AM
Low Compression thessler Goldwing Technical Forum 17 12-05-2007 06:49 PM
Is my 150psi compression low? 1983 1100 with 80,000mi. rjpok Goldwing Technical Forum 8 04-10-2007 12:15 PM
Low compression, GL1100 LD Hack Goldwing Technical Forum 11 03-18-2006 08:12 PM
