Fuel Gauge 2007 GL1800 - Page 3 - Steve Saunders Goldwing Forums
 8Likes
post #21 of 34 (permalink) Old 06-24-2018, 01:30 PM
not talking about the ratio of tach vs speedometer, those are mechanically linked and fixed.
you made it sound like the tach will not change vs the actual GPS speed. and it will, it has to.
the tach is linked to the tranny output shaft via the gearsets.
the diameter of the tire is going to change that ratio.
post #22 of 34 (permalink) Old 06-24-2018, 07:34 PM
Sorry I didn't mean it to sound that way, I apologize sincerely and have edited the word speed to speedometer, is that good enough?
Trust me, I do know how it works.
post #23 of 34 (permalink) Old 06-24-2018, 07:39 PM
Year: 2008
Seems like both of you are saying the same thing. If the bike is slower than the speedometer at say 3K RPM then with a taller tire at the same RPM/speedometer the bike is going a bit faster or closer to the speedometer reading. Isn't it????
Charlie
flylow is offline
post #24 of 34 (permalink) Old 06-24-2018, 07:41 PM
Yes it is. John has the idea somehow that I have a different understanding of it.
post #25 of 34 (permalink) Old 06-24-2018, 08:05 PM
nah,
I was just trying to pointt out the language, should have gone to PMs and let you take care of it.....
when it comes to taking care of my bike, it is Dave who does it.....
post #26 of 34 (permalink) Old 06-24-2018, 08:42 PM Thread Starter
1955joker's Avatar
Year: 2007
Wow what a wealth of information from people on this site you guys are awesome I have learned a lot from y'all Thank you all for all the help.
I had about 120 miles on it at 1/2 tank I just didn't want what happened when I was bring it home to happen again and was getting nervous so I stopped and filled it up. I gonna wait until I'm closer to 200 miles before I fill up next time and see if the gauge goes below 1/4 . Who knows maybe I got lucky and it unstuck itself......... Nah I would never be that lucky.
Oh okay that makes sense then I thought it was like my 1500 and read off the front wheel. I'll check the GPS vs speedometer Thanks guys
By the way what a big difference between the 1500 and 1800 I'm having to learn how to ride all over again or it seems like it but I am lovin the 1800
DaveO430 likes this.
Everybody Has A Photographic Memory Some People Have Just Ran Out Of Film
1955joker is offline
post #27 of 34 (permalink) Old 06-27-2018, 07:36 AM Thread Starter
1955joker's Avatar
Year: 2007
Okay Well I filled up this morning gauge showed 1/4 tank it had 182.9 miles sense fill up it took 4.7 gallons so it should have had a little less than 2 gallons left in the tank. If I'm thinking right the gauge should have been setting close to empty with what was left in the tank. Do you know if you can buy just the sending unit or does the fuel pump come with it? I need to figure out which one of the sending units is bad first though
post #28 of 34 (permalink) Old 06-27-2018, 07:59 AM
See post #12. Obviously it's the lower one on the pump unit.
post #29 of 34 (permalink) Old 06-27-2018, 10:15 AM Thread Starter
1955joker's Avatar
Year: 2007
Yeah Dave that's the one I figured it was that one. I was just hoping you would tell me it was the other one LOL
post #30 of 34 (permalink) Old 03-29-2019, 08:50 AM Thread Starter
1955joker's Avatar
Year: 2007
Okay I finally got the time to replace the fuel pump and it's still the same thing. It will not read lower than 1/4 tank I had 225 miles on it and it was still sitting on 1/4 tank and the low fuel light never came on. When I filled up it took 5.7 gallons. I guess I can try replace the other float. Is that the one that works the low fuel light? I wouldn't think it would be the fuel gauge cause it will go to empty when I turn the key off. I just thought of something else I don't remember if the low fuel light comes on when I turn the key to on. I'll check that this afternoon when I leave work. If it don't and the other float works the low fuel light that may be the problem?
Fuel gauge andtemparature gauge not working and rear suspension light on ssbn729 Goldwing Technical Forum 3 03-03-2017 03:20 PM
1983 goldwing dash/cluster/fuel gauge/temp gauge plastic cleaning otto Goldwing Technical Forum 5 04-02-2011 04:51 PM
Temp gauge and fuel gauge GL1100 whiteeagle1 Goldwing Technical Forum 2 09-06-2010 06:29 PM
GL1100 fuel gauge and temp gauge stop working sometimes? Tom2 Goldwing Technical Forum 6 06-29-2010 09:28 AM
temp gauge and fuel gauge-inop at times-gl1100-1982-naked CRAIGA Goldwing Technical Forum 13 04-21-2005 09:44 PM
