Fuel Gauge 2007 GL1800 - Steve Saunders Goldwing Forums
 8Likes
post #1 of 34 (permalink) Old 06-19-2018, 09:38 PM Thread Starter
1955joker's Avatar
Year: 2007
Okay here goes the first for this bike. It's a new to me 2007 GL1800 The fuel gauge was reading 1/4 tank and I ran out of gas. Could the float be sticking at 1/4 tank? It couldn't be that simple could it?
Side note I had a guy on a bike stop He went and brought a gas can and fulled it with gas and wouldn't take any money. I wish he would have given me his name but he wouldn't he just said pay it forward. He was a young man with an old school heart. That did this old man heart good knowing there are still some people teaching old school ways.
Everybody Has A Photographic Memory Some People Have Just Ran Out Of Film
1955joker is offline
post #2 of 34 (permalink) Old 06-19-2018, 09:57 PM
It would be helpful to know how much it held to fill it up. I think the low fuel light should have came on regardless if the float was stuck.
post #3 of 34 (permalink) Old 06-19-2018, 09:59 PM
you should have had the Low Fuel light shining in your eyes about 1.1 gallons before running out of fuel.
I carry a 1 gallon leak proof jerry can in the right saddle bag, just in case.
I cannot afford to be caught out in the open in high temps, would have a heat stroke.
as for the fuel gauge, most of them read pretty darn close on the 1800s....
something caused your fuel gauge to not read right.
as Dave mentioned, if you were truly empty, it would take right at 6.7 gallons of fuel.
I pumped in 6.4 once up near Oark, Arkansas.
post #4 of 34 (permalink) Old 06-19-2018, 11:35 PM Thread Starter
1955joker's Avatar
Year: 2007
The gas can had 2 gallons in it and when I fulled it up it took 5 gallons. The low fuel light never came on and it was reading that it had 1/4 tank left in it. I'll check and see if the fuel light comes on when I turn the key on in the morning I didn't think about doing that until now. I was more interested in getting home before it started to rain again
AZgl1800 likes this.
post #5 of 34 (permalink) Old 06-20-2018, 05:52 AM
It must have been empty assuming you filled up pretty soon after, they are supposed to hold 6.6 gallons.
post #6 of 34 (permalink) Old 06-20-2018, 06:11 AM
All you need to do to see if the gauge & the low fuel light is working is disconnect the 2 pin connector at the front of the tank under the seat, the gauge should go to E and the light come on. There is a second level sensor on the fuel pump that could be the problem as it is the one that measures the level when the fuel gets low.
limpy45 likes this.
post #7 of 34 (permalink) Old 06-20-2018, 08:19 AM
Power Guy's Avatar
Model: Aspencade 1500
Do the newer bikes have the float rod issues like the 90's models? (they bend over time and need re-adjusted)
Power Guy is offline
post #8 of 34 (permalink) Old 06-20-2018, 08:47 AM
joe in calif's Avatar
Turning the key on only shows if the bulb is good, it doesn't mean that the system is working properly.
limpy45 likes this.
A NEW START ON 1/20/2017
joe in calif is offline
post #9 of 34 (permalink) Old 06-20-2018, 12:29 PM
Not that I'm aware of. Don't think the rod in the 1500s actually bent, they were just made that way or the resistance changed over time.
post #10 of 34 (permalink) Old 06-20-2018, 12:47 PM
Power Guy's Avatar
I know I had to bend mine slightly to get it to read correctly. Seems that I recall a post from sometime ago stating that they all had issues.
Fuel gauge andtemparature gauge not working and rear suspension light on ssbn729 Goldwing Technical Forum 3 03-03-2017 03:20 PM
1983 goldwing dash/cluster/fuel gauge/temp gauge plastic cleaning otto Goldwing Technical Forum 5 04-02-2011 04:51 PM
Temp gauge and fuel gauge GL1100 whiteeagle1 Goldwing Technical Forum 2 09-06-2010 06:29 PM
GL1100 fuel gauge and temp gauge stop working sometimes? Tom2 Goldwing Technical Forum 6 06-29-2010 09:28 AM
temp gauge and fuel gauge-inop at times-gl1100-1982-naked CRAIGA Goldwing Technical Forum 13 04-21-2005 09:44 PM
