GL1100 Timing belt question. - Page 2 - Steve Saunders Goldwing Forums
post #11 of 21 (permalink) Old 06-22-2018, 08:06 PM Thread Starter
Screw's Avatar
Model: GL1200 and GL1100
Checked wires again and signal wire colors on each coil all match.
GL1100
GL1200
KZ1000
Grizzly 600
CR250
Screw is offline
post #12 of 21 (permalink) Old 06-22-2018, 09:47 PM
OK, just for grins switch the wires from the front cylinders to the back, easier to do it at the coils.
post #13 of 21 (permalink) Old 06-23-2018, 03:26 PM Thread Starter
Screw's Avatar
Just back fired with plugs crossed. Do you see anything wrong. Also checking firing with timing light fires right on with the Mark's. Has to be valve timing issue I believe.
GL1100
GL1200
KZ1000
Grizzly 600
CR250
Screw is offline
post #14 of 21 (permalink) Old 06-23-2018, 05:09 PM Thread Starter
Screw's Avatar
I really think now its a exhaust problem Im about to drop the pipes and find out, wouldnt be the first time vermin built nets in pipes!
GL1100
GL1200
KZ1000
Grizzly 600
CR250
Screw is offline
post #15 of 21 (permalink) Old 06-23-2018, 06:36 PM
I think I would put the right cam back 1 notch but that's not enough to cause your problem. Is it backfiring through the intake? I just worked on a little Honda XR70 last week, when I first got it started it didn't make any exhaust noise then it spat out a bunch of acorns.
post #16 of 21 (permalink) Old 06-23-2018, 09:22 PM Thread Starter
Screw's Avatar
Well I got a louder Bang any way!!!! Wife had to come see if I blew the garage up!! LMAO! I'm at a loss going to give it a rest, maybe I can get my Honda tech to take a look he's off tomorrow anyway. He one's me one for fixing his truck any way. If that doesnt work i will pull the heads and look for something wrong with them. Since im sure the firing order is right. Only thing i can think is maybe a bent valve from prior to my getting it.
GL1100
GL1200
KZ1000
Grizzly 600
CR250
Screw is offline
post #17 of 21 (permalink) Old 06-23-2018, 11:38 PM Thread Starter
Screw's Avatar
Well, 4 bent intake valves.
GL1100
GL1200
KZ1000
Grizzly 600
CR250
Screw is offline
post #18 of 21 (permalink) Old 06-23-2018, 11:42 PM Thread Starter
Screw's Avatar
Well at least I know Im not losing my mind, on this bike anyway!
GL1100
GL1200
KZ1000
Grizzly 600
CR250
Screw is offline
post #19 of 21 (permalink) Old 06-24-2018, 05:53 AM
A compression check and/or leakdown test would have saved a lot of time.
Bike...and Dennis likes this.
post #20 of 21 (permalink) Old 06-24-2018, 12:30 PM Thread Starter
Screw's Avatar
Yea, I got to get a adapter for my gauge. When I tried, mine was too big.
GL1100
GL1200
KZ1000
Grizzly 600
CR250
Screw is offline
Timing timing, timing (epilogue) 1981 GL1100 Lew Goldwing Technical Forum 4 09-16-2006 10:59 PM
Timing, timing timing (still more questions) Lew Goldwing Technical Forum 8 09-04-2006 05:19 AM
Timing, timing, timing (more questions) Lew Goldwing Technical Forum 22 08-22-2006 11:16 AM
Timing, timing, timing Lew Goldwing Technical Forum 9 08-18-2006 04:50 PM
Another timing belt question Momboy007 Goldwing Technical Forum 4 09-23-2005 02:18 AM
