GL1800 no start - Steve Saunders Goldwing Forums
post #1 of 16 (permalink) Old 07-02-2018, 08:31 PM Thread Starter
Year: 2006
Model: 1800 anti lock nav
Exclamation GL1800 no start
Hi all, did the first road test with the repairs done. (new bag rack, new left saddle bag and associated plastic parts).
Thought I had the cat by the tail, so after a couple of hours and 125 miles I stopped for lunch. Then decided to fill the tank, started up and went across the street. Topped it off, jumped on, hit the starter
NADA. Rechecked all the usual culprits, kill switch? on, neutral switch? on. kickstand? up. Cycle the key,
fuel pump on, FI light out, ABS light on, oil pressure light, on. hit the start sw, heard the solenoid click,
no turn of the starter.
Long to short, bump started, (very easy btw), rode home with no problems.
Interestingly, for giggles, I tried reverse to put it away and reverse worked. Shut it off and immediately tried to start, no joy. Neither did reverse work again.
I'm thinking start relay B in some fashion, so here's my real question.
Do I really have to pull the left bag to get to the relay? Any short shortcuts for troubleshooting?
If not the relay(s), I 'm at 53k miles, am I looking at a starter brush replacement?
Thanks for your input!
Tim A
thoughtfully submittedto be torn asunder for your amusement.
gamechtoo is offline
post #2 of 16 (permalink) Old 07-02-2018, 08:36 PM
rayjoe's Avatar
No Start
Do the simple checks first. How old is your battery?
Rayjoe
rayjoe is offline
post #3 of 16 (permalink) Old 07-02-2018, 08:46 PM Thread Starter
Year: 2006
it's about two and half years young. 12.7 vdc static , hydrometer reads 1275 for each cell
post #4 of 16 (permalink) Old 07-02-2018, 09:23 PM
Magic Moderator
trike lady's Avatar
You're using a conventional battery?
May I suggest a maintenance free battery.
What is the CCA of the battery?
Retired trike builder.
trike lady is offline
post #5 of 16 (permalink) Old 07-02-2018, 09:23 PM
Did you check the battery terminal bolts? BTW what year? 200t doesn't help.
post #6 of 16 (permalink) Old 07-02-2018, 09:40 PM
big PIA
MysticFour's Avatar
lol, I would bet 2005 or 2006 since they are above the t
MysticFour is online now
post #7 of 16 (permalink) Old 07-03-2018, 05:39 AM
Good catch, that didn't occur to me.
post #8 of 16 (permalink) Old 07-03-2018, 05:42 AM
Logically 06 since it does have navigation.
post #9 of 16 (permalink) Old 07-03-2018, 12:40 PM
Year: 2008
Slipped past me, I read it as a 2001.
Charlie
flylow is offline
post #10 of 16 (permalink) Old 07-03-2018, 08:03 PM Thread Starter
Year: 2006
update
good questions all,
This is a 2006 model
The battery is a 270cca, and just to be sure, I hooked up my 700cca battery from the truck and tried a start. NADA, same as before.
At least it is staying broke, I hate those intermittent electrical problems! So, bit the bullet and yanked the left bag. In the morning I'll run the trouble shooting guide for A & B, even though I'm 75% sure I'll find the start B to be the culprit.
Thanks again for your suggestions, I'll update the thread as soon as I know something.
HAPPY FOURTH OF JULY!!!!!!!!
no neutral light / no start 1500 biker4jesus Goldwing Technical Forum 10 04-12-2011 08:13 AM
GL1800 No music, no turn signals and no horn? Help!! wjohnmax Goldwing Technical Forum 8 09-26-2010 11:04 AM
1989 GL1500, no start-no spark-died w/driving-all testing from manual-ok CHI-MUKWA Goldwing Technical Forum 3 07-26-2010 03:34 PM
No Neutral light and no start FlyLikeABandit Goldwing Technical Forum 18 01-08-2009 03:01 PM
Update on the No Start -- No no taillight ElvisTorino Goldwing Technical Forum 2 04-17-2006 11:12 PM
