??? Power, Loose wire - Steve Saunders Goldwing Forums
 6Likes
post #1 of 11 (permalink) Old 07-09-2018, 02:28 PM Thread Starter
McFirefighter's Avatar
Year: 1990
Model: Aspencade
Send a message via MSN to McFirefighter Send a message via Yahoo to McFirefighter Send a message via Skype™ to McFirefighter
I went out to go for short ride today and when I turned the switch on my head lights came on then went right back off, this happen to me sat. but I put a charge in the battery and she started right up, but when I went out today no lights and won't start, every thing else works horn, turn sig, radio. I put another battery in her and when I turn the switch on the head lights came on went back off now nothing, I check all the fuse's on the left side all ok, I dont know what else to try anyone got any idea's. I did read the tread on here about won't start but I checked all the fuse on the one side. Help Please MCFF She is a 1990 GL1500A
Patriot Guard Rider #144639
McFirefighter is offline
post #2 of 11 (permalink) Old 07-09-2018, 03:47 PM
Magic Moderator
trike lady's Avatar
Relay #3 swap it with one in the box that has the same value. That one goes bad over time.
Retired trike builder.
trike lady is offline
post #3 of 11 (permalink) Old 07-10-2018, 03:44 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
??? No Power
Does this mean "no lights" anywhere...?? Head lights, dash lights, neutral light....etc.....??
Assuming you have a good strong battery and tight clean connections............!!
If so, check the Main Fuse B (55-amp) Dog Bone and its connections by the battery. It powers the following:
1. The # 2 Ignition/Cruise (15-amp) Fuse (Fuse powers the # 8 Ignition/Cruise Relay)
2. The # 3 Stop (15-amp) Fuse (Fuse powers the # 2 Stop Lights Relay)
3. The # 5 Headlight (15-amp) Fuse (Fuse powers the # 4 High and # 1 Low
Beam Relays)
4. The # 6 Air Pump (10-amp) Fuse (Fuse powers the # 5 Air Pump Relay)
5. The # 8 Tail Illumination (15-amp) Fuse (Fuse powers the # 3 Tail Main Relay)
Also check the Main Fuse A (30-amp) and its connections located with the starter relay A by the battery. It powers the ignition switch.
Did you check for input/output voltage on those fuses....??
redwing52 likes this.
DBohrer is online now
post #4 of 11 (permalink) Old 07-12-2018, 07:15 PM Thread Starter
Year: 1990
Model: Aspencade
The thing of it all guys is if I put the charger on the batt. and let it charge for a while it will start and every thing is like norm. Turn it off let is set over night same thing in the morning the headlights come on and then goes right off and no insterment panel lights except the cruise on light. Every thing else works???? horn, signal lights all but the curb lights that someone has hooked up for driving lights. Charge the batt for a while and wala starts and runs like norm. I am at a stand still I bought 2 new batt. thinking the 1st one was bad but when I installed new batt. nothing until i put it on the charger for a bit. Then fires right up. ???? Please help. MCFF
post #5 of 11 (permalink) Old 07-14-2018, 02:54 PM
DBohrer's Avatar
Electrical Issue
Observation and questions.....!
Then you had a "low voltage" battery.
Then you have a "low voltage" battery again. Something is draining the battery (or you have a battery issue).
Day 1...After the bike starts (with a fully charged battery), turn off the engine then disconnect the negative battery cable.
Check the battery voltage (make note of the voltage).
Day 2...Check the battery voltage again. Compare the day 1 and day 2 voltage readings.
What is the day 1 and day 2 voltage readings.....?? Be specific such as 12.7, 12.2, 11.9. 10.8 or whatever...!
If the day 1 and day 2 voltage readings are the same or exceptionally close, then you probably have an additional voltage drain on one or more of the bike (or add on) circuits on the bike.
Note: The GL1500 needs a very strong battery to start.....!
Where did you get the new batteries, what brand name, how many amp hours, what is the CCA, did you check the voltage on the new batteries, did you load test them.......!!
post #6 of 11 (permalink) Old 07-14-2018, 03:23 PM
glhonda's Avatar
Is this a crank and no start condition, or a no crank scenario?
glhonda is offline
post #7 of 11 (permalink) Old 07-15-2018, 09:28 AM Thread Starter
Year: 1990
Model: Aspencade
Well guys and gals after all the test's that I have done I finely figured it out!! thanks to trike Lady it was a loose ignition relay, I don't have any idea what the deal was when I would charge the batt. it would
start I guess the relay was just making contact from me moving the bike around and moving wires. The relay was not snapped in good and was just making contact when I was moving things around I guess.
Thanks so much for everyones ideas and help. And again special thanks to Trike Lady for sending me the idea to check all the realys. MCFF
redwing52 and flylow like this.
post #8 of 11 (permalink) Old 07-15-2018, 02:14 PM
Magic Moderator
trike lady's Avatar
You're welcome.
post #9 of 11 (permalink) Old 07-22-2018, 09:32 PM
DBohrer's Avatar
???..Power, Loose Wire
Just to keep things accurate on this issue and not "mislead" anyone....!
It was a loose Tail Main Relay # 3 (not a loose ignition relay)
I know there are folks who rely on what resolves various issues and use it for future reference....!
corkya likes this.
post #10 of 11 (permalink) Old 07-22-2018, 10:16 PM
Magic Moderator
trike lady's Avatar
In the second post it states 'Relay #3' I make no reference to calling it an 'Ignition Relay'.
I posted the diagram with the various relays in the relay box.
Mine was the suggestion of checking the relays.
Wire in 17P Coupler is loose ortiger General Motorcycle Discussion Forum 2 07-27-2012 04:23 PM
Loose wire, GL1100 palmpalm Goldwing Technical Forum 5 06-22-2012 01:04 PM
Temp Gauge out GL1000, wire loose, how to put it back? WingForChrist Goldwing Technical Forum 1 09-12-2010 08:03 AM
5 wire to 4 wire Converter Diagram? William_86 Goldwing Technical Forum 10 07-06-2010 11:25 AM
wire up to a 4 wire trailer from 6 wire plug! vv0350 General Motorcycle Discussion Forum 3 04-10-2007 07:59 PM
