04 speedometer - Steve Saunders Goldwing Forums
post #1 of 3 (permalink) Old 07-11-2018, 08:38 AM Thread Starter
shinner29's Avatar
Year: 1996/ 2004
Make: honda
Model: gl 1500 gl 1800
04 speedometer
anyone know how the speedometer works on an 04? it is different than my 96 and is off by 4mph, going 60 on the bike =56 in reality. can they be adjusted? thanks again.
Today is the first day of the rest of your life.
shinner29 is offline
post #2 of 3 (permalink) Old 07-11-2018, 08:44 AM
joe in calif's Avatar
The 1500 speedo runs of a cable the 1800 does not run off a cable. Just about all 1800 are off by that much. Honda corrected it in 09 or 2010. You can correct it by putting a speed healer on it
http://gl1800riders.com/forums/5-gl1...?action=thread
Or as I did and a lot of others do, when you need a rear tire go to 70 series instead of the 60 that it comes with
A NEW START ON 1/20/2017
joe in calif is offline
post #3 of 3 (permalink) Old 07-11-2018, 10:06 AM
on the 1800s, Honda switched things up.
the speedo now runs off the output shaft of the transmission.
and my 2002 with the Michelin CT is reading 6 mph faster than GPS speeds at 60-70 mph.
so, if the speed limit is 65, I put the Speedometer at 71-72
actually, I just set the GPS to read out MPH only and use that instead.
if, it bothers you enough, here is a fix for you.
https://www.healtech-electronics.com/products/sh/
retails on Amazon for $110
GL1800 '04 OEM speedometer (miles) akm10 For Sale/Wanted Forum 0 03-23-2006 02:35 AM
New to group, questions about 04 Wing Dan Shipek Goldwing Technical Forum 6 10-15-2004 12:25 PM
Two Ton Run 04 update wingdo Events 3 09-29-2004 06:51 PM
Two Ton Run 04 wingdo Events 3 08-12-2004 11:27 AM
Two Ton Run 04 Marky Events 0 07-08-2004 08:07 PM
