It Worked!! Got the rear brakes bled. GL1500 - Steve Saunders Goldwing Forums
 5Likes
  • 3 Post By oldmopars
  • 2 Post By Ken Bergen
post #1 of 10 (permalink) Old 07-24-2018, 05:55 PM Thread Starter
Model: GL1100 Interstate
One of the new Goldwings I picked up, the 1500 had no rear pedal, air in the lines. I played and played with it with no success.
Then I watched a video about how to bleed it. He said to put a heavy weight on the pedal over night. I used a small jack handle to keep it down.
I came back out the next day and I was able to get the brakes to bleed and I now have a nice hard pedal. May have to send back the parts I ordered. I thought for sure I was going to have to replace the rear master and was not happy about the amount of work involved.
AZgl1800, DBohrer and limpy45 like this.
oldmopars is offline
post #2 of 10 (permalink) Old 07-24-2018, 06:00 PM
Magic Moderator
trike lady's Avatar
That's good news.
Retired trike builder.
trike lady is offline
post #3 of 10 (permalink) Old 07-24-2018, 10:15 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
Always good when a plan comes together....!
DBohrer is offline
post #4 of 10 (permalink) Old 07-24-2018, 10:25 PM
So Henry's Law has more applications that giving divers the bends.
Who would've thought?
Ken Bergen is online now
post #5 of 10 (permalink) Old 07-25-2018, 10:49 PM
AaronzDad's Avatar
Year: 1987
Model: GL1200A Aspencade
I don't get it.
After searching around on yootoob I found (I think) the video referenced but I don't understand what is happening here.
What does pressure in the lines do for the air bubbles in the lines? Why would leaving pressure in the lines for a longer period of time help remove the air? Where do the air bubbles go? If they are traveling up (which they have to do) then they are stuck at the pedal/master cylinder valve and can't get into the reservoir to be eliminated.
Right?
He said open the bleeder valve before removing the weight from the pedal.
But if there is a bunch of air trapped just below the Master Cylinder valve shouldn't you just release the pressure and let the air float back up into the reservoir?
But of course that rarely works because it's almost never a straight upward shot into the reservoir.
What am I missing?
AaronzDad is offline
post #6 of 10 (permalink) Old 07-25-2018, 10:57 PM
Originally Posted by AaronzDad View Post
I don't get it.
What am I missing?
Henry's Law.
post #7 of 10 (permalink) Old 07-25-2018, 11:22 PM
AaronzDad's Avatar
Year: 1987
Henry's Law.
So wouldn't the dissolved air in the line just degas once the pressure is released?
Still doesn't make sense. If Henry's Law is what's at work here then as soon as the pressure is released it should fizz up like opening a bottle of soda.
post #8 of 10 (permalink) Old 03-29-2019, 12:29 AM
MICK MACK's Avatar
Year: 84
Make: Aspencade
Model: GL 1200A
I thought it was Boyle's Law? from MEN OF HONOR ... u are a LUCKY MAN... I hope my rear brake caliper rebuild from STUCK pistons in caliper= no rear brake, works ok. parts coming, took line off and hung it up as high as I could get the line, higher than the back brake master cylinder. that should keep the fluid in the system and the air bubbles out?? just hate running all that old nasty brake fluid thru the freshly rebuilt with love caliper/pistons/O rings.
MICK MACK is offline
post #9 of 10 (permalink) Old 03-29-2019, 05:21 AM
Monkey with a Football
Rudy's Avatar
The spongyness will return. I always stuck a short piece of 2x2 in there to hold the pedal down when parked in the garage to prevent that. It did.
Rudy
wasn't too much fun”
Rudy is offline
post #10 of 10 (permalink) Old 03-29-2019, 09:57 AM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
[QUOTE=oldmopars;5772831... put a heavy weight on the pedal over night. I used a small jack handle to keep it down...[/QUOTE]
I find that a 1-Gallon Can of Paint is the P-E-R-F-E-C-T weight setup, for this operation... simply Hang it from the pedal
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
Linked brakes. had pressure before I bled the rear. muaymendez1 Goldwing Technical Forum 3 08-27-2008 07:36 AM
Just replaced brake lines, can't get it bled. Help! scadaman29325 Goldwing Technical Forum 13 03-18-2008 09:15 PM
I think I Worked For This Company stretrod48 Fun Forum 2 03-08-2007 05:14 AM
Phew, it worked! wingnut General Motorcycle Discussion Forum 65 01-06-2007 06:39 PM
Brakes, brakes and more brakes. rear caliper rubbing disc Rescuer Goldwing Technical Forum 6 04-01-2006 07:30 PM
