86 gl1200 sei - Steve Saunders Goldwing Forums
 2Likes
post #1 of 25 (permalink) Old 07-26-2018, 08:51 AM Thread Starter
Justin Whaley's Avatar
Model: 1986 gl1200 aspencade sei
86 gl1200 sei
Probably looking at a stator change within the next month. I am still needing to test mine. Can anyone tell me if i need to test in ac or dc since it is before the regulator rectifier and what level i should be looking for for each wire?
Justin Whaley is offline
post #2 of 25 (permalink) Old 07-26-2018, 10:35 AM
AC, with it disconnected. You should get 50 to 60 VAC from each pair A-B, A-C & B-C. The DC test is bogus, doesn't work.
post #3 of 25 (permalink) Old 07-26-2018, 10:55 AM Thread Starter
So what you are saying is i need to bridge my negative and positive wires from my meter between the posts in the order you stated with the bike running and see what is read, or do i need to connect negative to negative on battery and just check all three plugs?
post #4 of 25 (permalink) Old 07-26-2018, 11:08 AM
it is Alternating current, there is no Positive or Negative terminal.
you have 3 wires. choose two of them and place the meter leads across them, w/o wondering which is which.
then hold one lead, move the other voltmeter lead to the next one in clockwise order, and that should read the same a/c voltage.
then hold the last lead, and leap frog again with the meter lead....
as Dave said, if you mark them "A" and "B" and "C"
measure across
A-B
B-C
C-A
and write down what you find and report back here.
again, the meter must be in A/C volts
post #5 of 25 (permalink) Old 07-26-2018, 11:48 AM Thread Starter
measure across
A-B
B-C
C-A
Alright will do, it will be next week as I am out of state.
post #6 of 25 (permalink) Old 07-26-2018, 11:49 AM
rayjoe's Avatar
test
Justin,
It's the three wires from the stator. The battery is not part of the test.
Also check to make sure the connector from the stator to the wiring harness is not melted or corroded.
Rayjoe
rayjoe is offline
post #7 of 25 (permalink) Old 07-26-2018, 12:16 PM Thread Starter
Originally Posted by rayjoe View Post
Justin,
Rayjoe
Ok thanks for the info I will hopefully be testing it next week.
post #8 of 25 (permalink) Old 07-26-2018, 01:14 PM
oh, forgot to mention the OSHA required statement.
do not hold those bare leads in your bare hands!
there will be about 70 yelps out of you in hurry.
post #9 of 25 (permalink) Old 07-26-2018, 01:18 PM Thread Starter
Haha that is true!!! While on the subject do you or anyone else have any good leads on videos for engine removal? Just in case it comes to that.
post #10 of 25 (permalink) Old 07-26-2018, 01:42 PM
Ken Bergen is online now
85 Ltd-86 Sei-87 lower corning lights-sei fairing side lights CWN For Sale/Wanted Forum 1 09-21-2014 08:37 AM
85 ltd/86 sei corning lites-sei side marker lites CWN For Sale/Wanted Forum 0 04-22-2013 07:28 PM
'86 GL1200 ASPY SEI guitarman1959 Goldwing Technical Forum 4 03-09-2007 04:33 PM
86 GL1200 SEi Jimmer Goldwing Technical Forum 15 10-03-2006 09:33 AM
86 GL1200 sei McTavish General Motorcycle Discussion Forum 5 03-25-2006 07:53 AM
