95 GL1500SA failure to start - Steve Saunders Goldwing Forums
 6Likes
post #1 of 15 (permalink) Old 07-29-2018, 09:40 AM Thread Starter
seabat's Avatar
Model: GL1500SE
Send a message via MSN to seabat
trying to sell my 95 1500 I let a prospective buyer take a ride around several blocks, when he returned he parked in the wrong spot, when I tried to start it to move no luck, the starter would not engage, all the lights would go out. After doing some checking I found I had a 9 + voltage going to the starter, further checking
showed #2 starter solenoid was closed causing the voltage, checking farther, found that #3 relay to be power supply for it. Need help in my deductions in case I'm wrong before I start replacing components.
seabat is offline
post #2 of 15 (permalink) Old 07-29-2018, 10:41 AM
Your battery is dead.
post #3 of 15 (permalink) Old 07-29-2018, 11:31 AM
dj norm's Avatar
Model: Goldwing SE
Send a message via MSN to dj norm
I would go for a good battery check also
Norm.
Arte et marte.
dj norm is offline
post #4 of 15 (permalink) Old 07-29-2018, 12:08 PM Thread Starter
seabat's Avatar
Model: GL1500SE
No, replaced the battery and still the same problem
seabat is offline
post #5 of 15 (permalink) Old 07-29-2018, 01:08 PM
First, the #3 relay has nothing to do with starting. If you are still only getting 9v to the starter that's not enough.
DBohrer likes this.
post #6 of 15 (permalink) Old 07-29-2018, 02:13 PM
as all have said, put a voltmeter on the battery terminals and watch to see how much it holds up to while it is cranking the engine over...
if the battery drops below 12 volts very much, it won't start.
11.5 is iffy
10.5 is dead battery.
redwing52 and DBohrer like this.
post #7 of 15 (permalink) Old 07-29-2018, 02:37 PM
As John and others said, put the voltmeter across the battery terminals and check battery voltage WHILE TRYING TO START THE BIKE. If you don't see 10 volts or so the battery is no good. If voltage stays at 12 plus you have high resistance in the starter circuit. Could be a dirty connection somewhere or a bad solenoid( relay "A" or "B") Check the battery and then check back for more info. Remember 10 plus volts while trying to start. Checking at the battery.
theRide likes this.
redwing52 is offline
post #8 of 15 (permalink) Old 07-29-2018, 03:34 PM
brownfoxx1's Avatar
Make: gl-1500
Model: Interstate with roadsmith trike HT1500 kit
you know you can use a heavy screw driver across the terminals on the relay to see if it works. just make sure the battery voltage is 12 volts. also is you have any idle issues cap the two jets on the carbs. see my avatar. i;ve done this and the idle rpm settled down. don't know why but it works. going on 3 months now.also if your fuel pump quits, you can hot wire it. useing the left phillips screw above the fuses. thats positive. the right screw is negative. . its hot when the key is on. just remember to fuse the line with a 5 amp fuse.
brownfoxx1 is offline
post #9 of 15 (permalink) Old 07-29-2018, 03:45 PM
Originally Posted by brownfoxx1 View Post
also is you have any idle issues cap the two jets on the carbs. see my avatar. i;ve done this and the idle rpm settled down. don't know why but it works. going on 3 months now..
Showing you have a vacuum leak somewhere.
post #10 of 15 (permalink) Old 07-29-2018, 05:07 PM
GoldwingA1500's Avatar
Model: Goldwing GL1500 Aspencade
Yep...sounds like you need a new battery.
GoldwingA1500 is offline
88 wheels to 95, 95 to 88 swap out Chromo Goldwing Technical Forum 7 06-17-2012 04:08 PM
Install new hitachi 95 amp and dampers on 95 wing craig stewart Goldwing Technical Forum 4 04-29-2012 06:45 AM
95 GL1500SE, No neutral light, will not start rgw5944 Goldwing Technical Forum 9 08-29-2010 06:34 AM
GL1800 failure to start JupiterJim Goldwing Technical Forum 11 06-09-2009 03:11 PM
95 1500 Won't Start deeppurple1500 Goldwing Technical Forum 4 04-24-2007 09:18 PM
