Left Brake light not working. 88' GL1500 - Page 2 - Steve Saunders Goldwing Forums
 4Likes
post #11 of 15 (permalink) Old 08-13-2018, 01:43 PM
Bellboy40's Avatar
Year: 2000 & 1994
That connector is right there near the brake/tail light assembly. If you read voltage there with the brake on (and ignition switch on) you know everything back to that connector is good. You should be able to see the wire go from that connector to the light socket and another green/yellow going back toward the splice where the power is coming from. The trouble almost has to be in that area because you said the other side works and it gets its power from the same source (but through another connector on the other side).
If you have a Harbor Freight near you, they often have a coupon for a free voltmeter when you purchase anything else there. Or you could buy a test light there for less than $5.00 that you could use to test for battery voltage at the connector.
Larry
-- Albert Einstein
Bellboy40 is offline
post #12 of 15 (permalink) Old 08-13-2018, 03:58 PM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
Originally Posted by Rick Taylor View Post
Did you check for voltage on the green/yellow wire with the brake on like DBohrer suggested? You should measure voltage from that wire to ground with the brake operated.
Bellboy 40, I'd don't have a volt meter to check it with. If I purchase one, what would it show me if faulty, and how would I go about fixing it?
Rick.............
Look at the attached diagram.
You have power at the splice.
You need to check the Green/Yellow wire between the splice and the 6-pin Red connector (left side of trunk)
You need to check for power on the Green/Yellow wire at the 6-pin Red connector (left side of trunk).
You need to check for power on the Green/Yellow wire at the brake light socket (left side of trunk).
You can use a test light to check for power. Put the alligator clip on frame ground, put the probe on the green/yellow wire. The test light should illuminate.
DBohrer is online now
post #13 of 15 (permalink) Old 08-13-2018, 04:49 PM Thread Starter
Rick Taylor's Avatar
Year: 1988
Model: GL1500
Bellboy 40 / DBohrer,
Looking at the diagram (thank you!) I see what you mean.
The problem must be either the socket or 6-pin connector on the left.
I'll pickup a test light and give this a shot.
I'm much better at repairing guitars than motorcycles!
ricknote
Rick Taylor is offline
post #14 of 15 (permalink) Old 08-13-2018, 06:39 PM
Bellboy40's Avatar
Year: 2000 & 1994
Hey Dave, that is a good sketch of the simplified wiring for the brake lights.
Larry
-- Albert Einstein
post #15 of 15 (permalink) Old 08-15-2018, 05:18 PM
DBohrer's Avatar
Year: 1967
[quote=Rick Taylor;5780397]Bellboy 40 / DBohrer,
I'm much better at repairing guitars than motorcycles![/quote]
I have two cousins that live in Fort Worth and North Richland Hills. Been to the Stockyards, saw Diamond Rio there a few years ago.
1500 GL- reverse not working - Neutral light off, but no reverse light appearing AlpineGoldwing Goldwing Technical Forum 18 03-24-2017 02:37 AM
Rear brake brake light switch not working Canoodle Goldwing Technical Forum 19 09-04-2015 12:45 AM
GL1800 left signal light not working SIDE-CAR 1800 HENK Goldwing Technical Forum 5 08-08-2010 06:56 AM
82 Aspencade Temp Gauge, Neutral Light & Tail Light not working BNC173 Goldwing Technical Forum 8 03-22-2009 09:59 PM
Brake light sticking on and cruise control not working ? TJ859 Goldwing Technical Forum 6 06-15-2006 10:55 PM
