gl1500 starts & runs thens dies - Page 3 - Steve Saunders Goldwing Forums
post #21 of 39 (permalink) Old 08-15-2018, 03:39 PM Thread Starter
brownfoxx1's Avatar
Make: gl-1500
Model: Interstate with roadsmith trike HT1500 kit
replaced fuel pump with a OEM pump. still starts then dies.
brownfoxx1 is offline
post #22 of 39 (permalink) Old 08-16-2018, 12:09 PM Thread Starter
brownfoxx1's Avatar
Make: gl-1500
whee does #3 vacuum hose go
anyone know where this vacuum hose with green tag goes on thegl-1500 I engine #3
post #23 of 39 (permalink) Old 08-16-2018, 01:01 PM Thread Starter
brownfoxx1's Avatar
Make: gl-1500
xxx
post #24 of 39 (permalink) Old 08-16-2018, 05:41 PM
That goes from the plastic nipple on the left side bottom of the air box to a T next to the PAIR solenoid valve on the left side of the frame.
How long will the engine run before it dies? And are you sure it's running out of fuel and not loosing ignition?
post #25 of 39 (permalink) Old 08-16-2018, 06:00 PM Thread Starter
brownfoxx1's Avatar
Make: gl-1500
starts the immediately dies, the won't restart. fuel new fuel pump you can hear it run and the terminal on top is hot. just added 2.5gal fuel. ho do i trouble shoot loose ignition?new relays 2 months ago and new fuses. i put diaelectric grease on then. bike ran geat 2 months then just died. i changed a newly installed fuel pump and got it to run 4 miles home. after i shut it off . i have this problem. thanks for the help lb the fuel shutoff valve is a new OEM one and has run ok. it is getting vacuum when you crank the eng. so i eliminated it and have same problem. whe the orginial ECU quit giving fuel, o ordered another used one with 37k. and it didn't provide fuel, so i did the hot wire of the fuel pump. that worked good for 2 months. ridden daily 8 miles or so.started with no choke help .in the am i might swap back to my ECU
post #26 of 39 (permalink) Old 08-16-2018, 08:18 PM
If you have a timing light connect it then start the engine while holding the trigger on the light and see if you can tell if the flashing stops before the engine stops turning. The try starting it again and watch for the light to flash. If you don't have a timing light pull 1 plug wire and attach a spark plug to it, lay it on the engine and do the same test.
post #27 of 39 (permalink) Old 08-16-2018, 09:01 PM Thread Starter
brownfoxx1's Avatar
Make: gl-1500
got a induction one thanks pumped old gas out and put in non-alcohol gas w/seafoam.will crank it in am.done
FRIDAY AM i'm getting spark on all 6 cylinders
changed ecu no help
ECU 2A is hot w/key on
pulled plugs looked good/ not fouled. dry
post #28 of 39 (permalink) Old 08-18-2018, 11:26 AM Thread Starter
brownfoxx1's Avatar
Make: gl-1500
i took the ECU out and installed the original ecu. just cranked no start. si i put the used bought ECU in , and the bike will start and run if you keep it above 2k rpm. when you let off it will slow down and die.
post #29 of 39 (permalink) Old 08-18-2018, 12:01 PM
Is the bike trouble free if the fuel pump is hot wired now?
redwing52 is offline
post #30 of 39 (permalink) Old 08-18-2018, 12:47 PM Thread Starter
brownfoxx1's Avatar
Make: gl-1500
i've road the bike 2 months without any problems. ya can;t seem to get a good one off of ebay. i did put a 5 amp fuse and a on-off toggle switch in-line with the fuel pump so i can shut it off when i need to
'85 Aspencade starts and then it dies saioro Goldwing Technical Forum 9 04-16-2016 09:59 AM
1994 GL1500 I no choke/dies twist throttle/dies tnkrtoy Goldwing Technical Forum 37 03-11-2016 03:55 PM
84 ASPY starts but dies when throttle is increased blu boy Goldwing Technical Forum 25 01-25-2011 09:34 PM
Gl1100 Starts/runs on only two cylinders Bearmandu Goldwing Technical Forum 6 09-12-2008 08:10 AM
1500 starts and then dies jpeg4god Goldwing Technical Forum 5 08-16-2008 06:04 AM
