gl1500 starts & runs thens dies - Page 4 - Steve Saunders Goldwing Forums
post #31 of 39 (permalink) Old 08-18-2018, 12:50 PM Thread Starter
brownfoxx1's Avatar
Make: gl-1500
Model: Interstate with roadsmith trike HT1500 kit
still won't idle . so you can't take it out and ride it.it will run if you rev it constantly. gave it a good carb cleaner spray while i had it running put a can of BG44K cleaner in front and rear tank. warmed it up till temperature came up. it will now idle at 2k and if you slowly throttle off it will slowly die. shut it off and let it cool off overnight
brownfoxx1 is offline
post #32 of 39 (permalink) Old 08-19-2018, 07:25 PM Thread Starter
brownfoxx1's Avatar
Make: gl-1500
bike run great. starts without choke. looks like it was the ECU needed to be reset. seeing how it doesn't have a reset button you have to disconnect it. i put the original ECU in and the bike would crank but not start. put the
extra ecu back in that i've had it in for 6 months and it started immediately. had to keed it above 2k with the throttle lock on, i let it run for 5 min. shut it off. and now it starts and idles at 1000 rpm. thats where i like it with this heavy trike.
post #33 of 39 (permalink) Old 08-20-2018, 03:49 AM
IIRC,
to calibrate the ECM, you need to start the bike, let it run at idle until the fans turn on.
shut it down, wait a minute, start it back up, and it should idle correctly.
how that would work on a carb'ed bike, don't know.
I know the 1800 has that procedure, can't recall on the 1500, but I am thinking that I had to do that on my 98 when I got it, it did not want to idle right.
post #34 of 39 (permalink) Old 08-20-2018, 05:51 AM
IIRC,
A 1500 ECU is what it is, there is no calibrating or resetting to it.
post #35 of 39 (permalink) Old 08-20-2018, 06:47 AM Thread Starter
brownfoxx1's Avatar
Make: gl-1500
yea, the only way to reset it is to
disconnect the battery
, disconnect the ECU
wait a bit the plug it back in.
post #36 of 39 (permalink) Old 08-20-2018, 08:11 AM
There is no battery power to it when the ignition is off. If it was resetable it would do it every time you shut it off.
post #37 of 39 (permalink) Old 08-20-2018, 04:13 PM Thread Starter
brownfoxx1's Avatar
Make: gl-1500
good to know. thanks lbi recomend useing a tooth pick in the 2 jets becaust one of the jets doesn't stick up very much so there's a danger of the rubber cap popping off.
post #38 of 39 (permalink) Old 09-05-2018, 05:24 PM Thread Starter
brownfoxx1's Avatar
Make: gl-1500
used the rear tank the other day till it stumbled then switched to front tank. no idle is 500 rpm. so i just took the covers off no i can spray the carb and change the fuel filter again.its really hard to get it off line as its a heavy trike, ans can't seem to throttle it to 1000 rpm.
post #39 of 39 (permalink) Old 09-17-2018, 02:21 PM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
Tried By-Passing the Fuel Shutoff?... so as to rule out an intermittent vacuum loss (which would shut off fuel supply)
Also might verify that the Rubber Isolators (1 between each carb and the Intake Manifold) are tight... The screw clamps (2 on each isolator) commonly loosen, causing an air leak and resulting Lean Condition
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
'85 Aspencade starts and then it dies saioro Goldwing Technical Forum 9 04-16-2016 09:59 AM
1994 GL1500 I no choke/dies twist throttle/dies tnkrtoy Goldwing Technical Forum 37 03-11-2016 03:55 PM
84 ASPY starts but dies when throttle is increased blu boy Goldwing Technical Forum 25 01-25-2011 09:34 PM
Gl1100 Starts/runs on only two cylinders Bearmandu Goldwing Technical Forum 6 09-12-2008 08:10 AM
1500 starts and then dies jpeg4god Goldwing Technical Forum 5 08-16-2008 06:04 AM
