GL1500 speedo again - Page 2 - Steve Saunders Goldwing Forums
 13Likes
post #11 of 18 (permalink) Old 08-19-2018, 05:35 PM
Originally Posted by Erdeniz Umman View Post
You don't need a lift to troubleshoot this problem.
Harbor Freight just put their motorcycle table lift on sale again !!!
$285 out the door
https://www.harborfreight.com/automo...ift-68892.html
cmhbob likes this.
post #12 of 18 (permalink) Old 08-19-2018, 08:19 PM Thread Starter
Did...did I do that?
Year: 1996
Model: GL1500SE
Start with the speedo cable and build a bike around it.
The idea has merit. That's sort of how they designed the A-10. "We've got this gun, and we need a plane to carry it."
Posted messages are packaged by intellectual weight, not volume. Some settling of contents may have occurred during transmission.
cmhbob is offline
post #13 of 18 (permalink) Old 08-20-2018, 08:17 PM Thread Starter
Year: 1996
Model: GL1500SE
OK, I'm a little new at this, but I think my speedometer cable isn't supposed to look like this.
I had the front fork seals done a few weeks ago. Would they have pulled the fenders, etc. for the fork seals? I wouldn't think so. I'm wondering if this is just age, or did the shop goof somehow.
At any rate, I was looking from underneath at the top end where the cable goes into the speedometer, and I don't see how I can get my fingers up in there. There's what looks like a guard keeping my fingers from getting to the upper nut. I've got the 94 manual that someone had uploaded; what page is that area on?
cmhbob is offline
post #14 of 18 (permalink) Old 08-20-2018, 08:23 PM
I'd guess they pulled the wheel without disconnecting the cable. Seems like they would have just replaced it but, these days, sleaze rules.
Take it back to them, but don't let them do the work. Get a new cable and folks here will guide you installing it. On the 15 its relatively easy.
cmhbob and DBohrer like this.
post #15 of 18 (permalink) Old 08-21-2018, 06:07 AM
galaxyhunter's Avatar
Model: 2000 Aspencade
This is a MAJOR league PITA. It can be done. I was able to get my hand in there, but I have a lift. If you get the bike at the right height, it is much easier. This is not a 10 minute job.
Carl
Honorary Rhino
NASSIR 6 - NASSIR 7
NASR 10 - NASR 11
NASR 12 Host in Galena
old bikes:
71FX Super Glide
86 Aspencade
galaxyhunter is offline
post #16 of 18 (permalink) Old 08-21-2018, 09:38 AM
DBohrer's Avatar
Year: 1967
Make: BSA Royal Star
Check the attached doc......! You can do this job.......!!!
File Type: doc GL1500 Speedometer Cable Replacement.doc (16.5 KB, 15 views)
cmhbob and Bellboy40 like this.
DBohrer is online now
post #17 of 18 (permalink) Old 08-21-2018, 09:49 AM
Bellboy40's Avatar
Year: 2000 & 1994
The procedure that DBohrer posted is a good one. That is how I replaced the one on my 94 1500. I had to use some pliers to break it loose on the speedometer end, then stood on the right side of the bike and reached up under there with my left hand to remove it. Kind of a pain to do but not so bad if you know the procedure.
Larry
-- Albert Einstein
Bellboy40 is offline
post #18 of 18 (permalink) Old 08-21-2018, 10:17 AM Thread Starter
Year: 1996
Model: GL1500SE
Thanks for that. It'll be a couple of days before I can get to it; I'll report back.
cmhbob is offline
Gl1500 coolant leak and squealing speedo cable or speedo Darren_Schmitz Goldwing Technical Forum 37 03-15-2017 02:07 PM
GL1500 Speedo drive gear - AGAIN VDIGUY Goldwing Technical Forum 3 09-12-2013 05:11 PM
GL1200 Interstate Speedo v. Aspencade Speedo 4evermetric Goldwing Technical Forum 1 11-28-2009 07:51 PM
Speedo/odo quit, magically working again chris in va Goldwing Technical Forum 1 12-14-2008 09:18 PM
Home Again, home again..... Jiggedy Jig! Cousin Jack General Motorcycle Discussion Forum 76 07-10-2008 06:42 PM
