GL1500 speedo again - Steve Saunders Goldwing Forums
 13Likes
post #1 of 18 (permalink) Old 08-18-2018, 11:56 AM Thread Starter
Did...did I do that?
Year: 1996
Model: GL1500SE
GL1500 speedo again
Lost my speedometer a while back, and had the local shop repair it. I don't have my receipt handy, but the notes I kept say "speedometer sensor replaced."
Now just over 1,000 miles later, it's failed again. I'm going to try to deal with it myself this time. Where to start: at the wheel, or at the other end?
Posted messages are packaged by intellectual weight, not volume. Some settling of contents may have occurred during transmission.
cmhbob is offline
post #2 of 18 (permalink) Old 08-18-2018, 12:01 PM
DenverWinger's Avatar
I'd disconnect the speedometer cable at the wheel end and try to turn the cable inside the sleeve to see if it's binding. I haven't had a 1500 speedo cable apart, but if it's like the 1100 there's a slot in the wheel end of the cable that mates with the drive unit. You could try to turn it with a screwdriver to see if the cable or speedometer itself is binding, that would wear out the plastic drive gear in short order....
cmhbob likes this.
1972 CL-350 (1980-1988) sold
1977 GL1000 (2002-2006) sold
1993 GL1500 Aspencade (2017-)
1983 Trav-Lite Camper (2010-)
DenverWinger is online now
post #3 of 18 (permalink) Old 08-18-2018, 02:29 PM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
When the speedometer sensor is bad, you will lose cruise control, radio auto volume, turn signal auto cancel function but not the speedometer, because it is totally mechanical.
So you should recheck the work done by the shop.
The problem may be because of the plastic gear in the front wheel, speedometer cable or the speedometer itself.
In order to narrow down the problem, you may disconnect the speedometer cable from the front wheel gear box, and try spinning it using a power drill rotating counterclockwise. Then you may find the culprit.
cmhbob likes this.
Erdeniz Umman is offline
post #4 of 18 (permalink) Old 08-18-2018, 02:35 PM Thread Starter
Year: 1996
Model: GL1500SE
I've lost all of the above, as far as I can tell.
Really wishing I had a lift, too.
cmhbob is offline
post #5 of 18 (permalink) Old 08-18-2018, 02:37 PM
You don't need a lift to troubleshoot this problem.
post #6 of 18 (permalink) Old 08-19-2018, 11:51 AM Thread Starter
Year: 1996
Model: GL1500SE
No, but it would make a few things easier. It's not nearly as simple to get up and down from the floor as it was 30 years ago.
DBohrer likes this.
cmhbob is offline
post #7 of 18 (permalink) Old 08-19-2018, 12:26 PM
DBohrer's Avatar
Model: '99 Gold Wing SE
I like the idea of working "smart" not "hard"......!!
Don't "cut off the horses legs"...."raise the barn door opening".....OR....."lower the door sill".....!!!
Don't raise the bridge.........lower the water............!!
DBohrer is offline
post #8 of 18 (permalink) Old 08-19-2018, 01:46 PM
So, you suggesting he turn the bike over so it's sitting on the trunk and windshield, to ease working on the speedometer cable?
cmhbob likes this.
post #9 of 18 (permalink) Old 08-19-2018, 01:48 PM
Some take shortcuts and leave the housing in place. They just change the internal cable only. The problem is if the housing is worn the new cable will bind in the old housing and fail. Is this possible? Always change the housing with the cable.
DBohrer likes this.
redwing52 is offline
post #10 of 18 (permalink) Old 08-19-2018, 01:50 PM
Start with the speedo cable and build a bike around it.
Erdeniz Umman likes this.
Gl1500 coolant leak and squealing speedo cable or speedo Darren_Schmitz Goldwing Technical Forum 37 03-15-2017 02:07 PM
GL1500 Speedo drive gear - AGAIN VDIGUY Goldwing Technical Forum 3 09-12-2013 05:11 PM
GL1200 Interstate Speedo v. Aspencade Speedo 4evermetric Goldwing Technical Forum 1 11-28-2009 07:51 PM
Speedo/odo quit, magically working again chris in va Goldwing Technical Forum 1 12-14-2008 09:18 PM
Home Again, home again..... Jiggedy Jig! Cousin Jack General Motorcycle Discussion Forum 76 07-10-2008 06:42 PM
