How do tie down a GL1500? - Page 2 - Steve Saunders Goldwing Forums
 10Likes
post #11 of 20 (permalink) Old 08-22-2018, 03:04 AM
I don't like to tie to the grab handles, seen them come loose when the bolt breaks.....
use a Single Strap and wrap it once around the rear wheel.
Tie it off to both sides of the trailer.
that is the only way I will trailer a bike.
post #12 of 20 (permalink) Old 08-22-2018, 07:53 AM
dwade's Avatar
Year: 1989
Model: Aspencade
I've had each of my 4 wings on a trailer either to bring them home or to take for repairs. What I do is bring the bike forward against the front frame rail so the bike can't roll forward, take a piece of cardboard or a heavy towel and lay across the the driver seat. Then take the ratchet straps and hook onto the top of the rear crash bar and cross over the seat to the opposite side, I do both sides like this then tie the front wheel to the front rail of the trailer. Never had one come loose.
My trailer is a 16' car hauler
Sent from my SM-G930P using Tapatalk
dwade is offline
post #13 of 20 (permalink) Old 08-22-2018, 07:56 AM Thread Starter
Model: GL1100 Interstate
I hauled bike about 400 miles in a normal trailer. Strapped down from the crash bars, pulling four different ways. Had no issues other than re-tightening a couple times in the first 50 miles, or so.
I'd guess, if you do I-5 and then I-90 it will be a breeze.
I take it you've considered taking a helper to drive the truck back for you?
Oh, and I rented a U-Haul M/C trailer to haul the '85 home and it fit easily.
I am going with my wife, but my truck is a 1 ton Dually 4x4 Service truck, and she does not feel comfortable driving it.
oldmopars is offline
post #14 of 20 (permalink) Old 08-22-2018, 08:37 AM
Toolcraft4100
toolcraft4100's Avatar
Make: Goldwing
Model: '91 Aspencade
I've tied my 1500 down on the deck of two different car ferries and once on a trailer. I tie the front down like most people suggest, but I loop soft straps around the passenger footrests and use ratchet straps from there. The footrests attach directly to the frame with a couple of pretty substantial bolts.
toolcraft4100
toolcraft4100 is offline
post #15 of 20 (permalink) Old 08-22-2018, 10:29 AM
Then you drive the truck and have her ride the bike.
post #16 of 20 (permalink) Old 08-22-2018, 11:27 AM
snowmoer's Avatar
Model: 1988 GL 1500, 2012 GL1800, 1977 GL1000 2012 KLR 650
Here is a photo of how I tied down my 1500. The 1800 is done the same way.
Please do not use engine guards, rear tip over bars, hand grab bars, straps over seats or on the side stand. These attachment points and bolts are not designed go take the forces that can be generated when towing. At least on the 1800, there are many posts on the GL1800 forum where people use the crash bars for tie down points and then find the mounting bolts are broken. The moving company that transported my bike from PA to CA use the rear crash bars as tie down points. When I put on my trailer hitch, sure enough, one of the bolts on each side where the strap was were broken.
The info that DBohrer is great! It will depend on how many tie down points and location on your trailer on how you tie it down. Using soft straps with ratchet straps on the lower triple clamp is a must. This pulls the bike to the front of the trailer. I prefer the frame as my backup to pull the bike forward. This also helps with the bike moving from side to side. Without a wheel chock, I would also put straps from the frame directly to the side of the trailer. The bike will want to tip over without the chock. This will stop this side to side movement. The rear tire point is good. This is keeping the rear of the bike from wanting to wag side to side on bumps. I had already removed the tire strap when I took the picture of the 1500.
I have been towing things on trailers for over 40 years. I have found that ratchet straps are the best. When you stop, check your straps, they will loosen up as the load finds it's spot on the trailer. With the ratchet straps, you just give them another click or two and things are tight again.
Dan
AMA Life
2012 GL 1800 Level 3
1988 GL 1500
1977 GL 1000
2012 KLR 650
snowmoer is offline
post #17 of 20 (permalink) Old 08-22-2018, 05:15 PM
It aint rocket science
DriverRider's Avatar
Model: The best
As a safety feature passenger grab rails are way over built with steel and hardened attaching bolts and are adequate for your tie down point.
Some guys cross thread the bolt holes and in those cases tie to frame.
J.D.
Internet myth buster
Starter ride
Rupp
Previous rides
Bultaco
Yamaha 360
Yamaha 650
WS Grand Chapter CT
DriverRider is offline
post #18 of 20 (permalink) Old 08-22-2018, 06:23 PM
I noticed that you also tie the front wheel to the vertical upright....
I don't see many people doing that, they just say "oh the fork tie down straps will hold it in place."
I have two vertical uprights on my trailer, the wheel slides in between them.
no wheel chock, trailer is too short.
umm, yes, but, I once had a tie down strap come loose, or it frayed out, or something.....
years ago, I now use only 1,000 lb rated tie down straps or better.
post #19 of 20 (permalink) Old 08-22-2018, 07:00 PM
I am absolutely against tying down the rear suspension in any way. Use the saddlebag guards to tie it to the sides of the trailer but let the rear suspension float, it will ride much better. It will stay upright with tie downs over the lower triple tree at about a 45 degree angle, make sure the bike is vertical. And be sure to put the side stand up.
When I brought my GL1000 home I rolled it up in the truck and used a tie down on each side at the front, got out and closed the tail gate. A young man there said he had some more tie downs I could have, I said it has 2, what more do I need. Hauled it 175 miles on crooked roads and it never moved.
AZgl1800 likes this.
post #20 of 20 (permalink) Old 08-22-2018, 08:53 PM Thread Starter
She does not ride, passenger only.
It's OK, I have to go by my Moms place about 1 hour away and pick up a couch, table, scooter and some shelves anyway.
Ways to tie a tie PurplePirate Miscellaneous Forum 8 01-18-2015 11:13 PM
GL1500 tie down failure efudd Goldwing Technical Forum 6 01-02-2014 09:56 AM
How do I tie down an Aspencade to a trailer? Marten General Motorcycle Discussion Forum 8 07-01-2011 11:17 AM
How do you trailer folks tie down your cooler? jimsjinx General Motorcycle Discussion Forum 27 01-12-2009 06:50 PM
Tie Down GL1500 sandiegobrass General Motorcycle Discussion Forum 10 09-25-2007 02:26 PM
