WASHING my Wing. I can't take the chance of washing my 2000 Gold Wing again? - Page 2 - Steve Saunders Goldwing Forums
 26Likes
post #11 of 22 (permalink) Old 08-22-2018, 10:22 PM
CrystalPistol's Avatar
I wholeheartedly agree, washing didn't cause a broken sprocket.
siouxindian likes this.
...( Candy Spectra Red )
'85 GL-1200 Aspencade
...( Vintage Red )
CrystalPistol is offline
post #12 of 22 (permalink) Old 08-23-2018, 05:05 AM
gt750's Avatar
Year: 2006
Model: GL1800A
Some detail is in order here. Pretty vague description. Help me understand the issue and the fix. Thanks.
It is NOT a good idea to use a pressure washer on your bike. If you wish to do it quickly, try some "S100" motorcycle cleaner. It'll cost $10.00/wash, but will do a good job, safely. I use "Meguiar's" products. A pail of hot water and a garden hose. Have a "J-Cloth" and a sponge.
I was so happy to be on my 'Wing that I patted her tank and was laughing in my helmet!
gt750 is offline
post #13 of 22 (permalink) Old 08-23-2018, 06:42 AM
dadztoy's Avatar
Year: 2009
Model: 2009 Silver GL1800 ABS
I'm with John... NEVER, EVER pressure wash a bike!!! My bike has never seen high pressure water and water from a hose maybe once or twice when extremely dirty, otherwise it's a wet towel or sponge...
4 wheels moves the body
2 wheels moves the soul
GL1800 HPNAM9
Double Darkside - BT-45
dadztoy is online now
post #14 of 22 (permalink) Old 08-23-2018, 07:20 AM
Peter Goldwing's Avatar
Year: 2008
Model: GL 1800
I put mine in a washing machine and select gentle cycle. Never had a problem.
Follow me on the spot
Peter Goldwing is offline
post #15 of 22 (permalink) Old 08-23-2018, 07:50 AM
rayjoe's Avatar
He never said what broke? What sprocket? Where?
Rayjoe
CrystalPistol likes this.
rayjoe is offline
post #16 of 22 (permalink) Old 08-23-2018, 07:50 AM
But don't put it in the dryer, it will shrink into a scooter.
post #17 of 22 (permalink) Old 08-23-2018, 07:58 AM
Magic Moderator
trike lady's Avatar
Looking at a parts diagram the only sprocket I located was for the oil pump, unless there's another one.
Retired trike builder.
trike lady is offline
post #18 of 22 (permalink) Old 08-23-2018, 08:07 AM
I assumed he is talking about the starter driven gear, nothing else makes sense.
post #19 of 22 (permalink) Old 08-24-2018, 06:42 AM
Andy Cote's Avatar
No rinse car wash
The Valkyrie can hydro-lock with gasoline if petcock leaks (manual and vacuum) and a carburetor needle valve leaks. When that happens, the starter gear is usually the weak failure point and could drop pieces into the engine requiring teardown.
I agree it would be really hard to get water in the intake of the Goldwing with a garden hose but this is the only thing that fits the limited description of the problem.
Back to the topic title, while I did wash my GL1500 with a bucket and sponge and rinse off with a hose, I never found a power washer to be necessary or desirable. In fact I just sold a windshield to a guy that had power washed his GL1500 and ended up peeling the anti-scratch coating off. No good things can come from this. When using the hose, worst I would get is some rough running until the plug wires, etc. warmed up and dried off.
I have switched to no rinse car wash for both cars and bikes. It's great and I can even wash inside the garage in the winter. The no rinse does not include any wax products (most car wash soap contains wax) but all vehicles have been ceramic coated so I don't want any wax. Perfect solution for me.
DARKSIDE #1500
2015 Goldwing - basic black
Ham Extra Class AC1R
Andy Cote is offline
post #20 of 22 (permalink) Old 08-24-2018, 01:09 PM
I don't think the pressure from a garden hose, even with a squirt nozzle attached, is much of a threat to a GoldWing. I use one when I do "wash" my bike. Here's the kicker.
That is usually when I have the bike torn down for a serious cleaning, and the intake is right there and open but I've never sprayed water into it. And, even if I did get a little in there, it would have to work its way through the air filter to get to the carbs, where it would probably sit at the bottom of the bowel.
My point is; to get enough water into the combustion chamber to cause metal stuff to break, it seems like you'd have bypass the air/fuel intake, wouldn't you?
2015 Honda Gold Wing And Gold Wing F6B Mark 40th Anniversary VS Jeff GoldWingFacts.com and Motorcycle.com News 1 05-10-2016 01:37 PM
Take a chance, and enrich your life....... Cousin Jack Miscellaneous Forum 7 03-05-2012 04:18 PM
Take a Chance On Me pinkpork Miscellaneous Forum 2 11-01-2011 04:28 PM
Some leds doesn't work after washing my Wing LANTIRN Goldwing Technical Forum 3 12-15-2008 04:30 AM
Had your wing quit after washing?? johnapool Goldwing Technical Forum 7 07-20-2005 05:35 AM
