Ugh that wobble... 84 Gl1200 - Steve Saunders Goldwing Forums
 6Likes
post #1 of 32 (permalink) Old 08-29-2018, 10:33 PM Thread Starter
Year: 1984
Model: GL1200 Aspencade
Hey everyone finally got my 84 GL 1200 back together. It has two new timing belts, a flushed coolant system, new front wheel bearings, fresh ATF in the front forks, new brake pads all the way around, new brake fluid all the way around and a new set of Continental Conti tour tires.
I've been chasing a wobble at about 30 and roughly 50 with your hands off the bar. Hands on the bar not a big deal bike is as smooth as silk. She needed tires so I pulled it apart rear wheel bearings look good splines look good everything was lubricated.
I took it out for a test ride after having been off the road for approximately the last month doing everything and to my surprise the wobble is still there. The first thing I looked at before any of this was done was the steering head bearings they're smooth as silk and no side to side play or front to rear.
Is this just something I have to live with? Just a reminder to keep my hands on the bar at all times? Maybe I'm just being too picky.
Linus is offline
post #2 of 32 (permalink) Old 08-29-2018, 11:21 PM
On mine, this has always been caused by a worn, poor quality rear tire.
Metzlers were the worst with Dunnies a close second. Bridgestone and Pirelli seem to be immune.
siouxindian likes this.
post #3 of 32 (permalink) Old 08-29-2018, 11:36 PM
life is good
siouxindian's Avatar
Make: gl 1500 interstate
Model: 91 interstate
yes you got something wrong my 1200 aspy did not do any wobly stuff maybe tire not seated on rim correct? keep lookin you will find it.
life is good.
siouxindian is offline
post #4 of 32 (permalink) Old 08-30-2018, 12:10 AM Thread Starter
Year: 1984
Skins are brand new with beads in them. Maybe I need to wear them in?
Linus is offline
post #5 of 32 (permalink) Old 08-30-2018, 12:22 AM
What brand and how much air?
post #6 of 32 (permalink) Old 08-30-2018, 02:14 AM
life is good
you dont wear them in you wear them out.
tamathumper likes this.
life is good.
post #7 of 32 (permalink) Old 08-30-2018, 08:17 AM Thread Starter
Year: 1984
Continential Conti-Tours, there is about 40 psi in the rear I didn't check it with my good gauge.
Put it on flat aired it up before I set her back down. Just aired it up for a shakedown run to make sure the wheels weren't going to fall off .
I should note the wobble is only on decel with my hands off the bars. No vibration to really speak of. Again am I being picky?
Linus is offline
post #8 of 32 (permalink) Old 08-30-2018, 08:26 AM
Wobble starts with the tires, no ifs ands or buts. No tire is perfect so things have to be done to dampen the wobble out. Have you retorqued the steering bearings?
post #9 of 32 (permalink) Old 08-30-2018, 08:32 AM Thread Starter
Year: 1984
I did check the rear wheel bearings and swingarm bearings while it was apart. Everything feels tight.
Linus is offline
post #10 of 32 (permalink) Old 08-30-2018, 08:35 AM Thread Starter
Year: 1984
I left well enough alone with the steering head bearings because they checked out with the front end off the ground. There is no slop, I did put dynabeads in it, is it possible they are settled and stuck because it's been sitting so long? I also need to check my pressure with a reliable pressure gauge.
Linus is offline
GL1200 clutch...............ugh ddrichard Goldwing Technical Forum 11 06-05-2012 07:14 PM
wobble wobble wobble beachbuddy0253 Goldwing Technical Forum 6 09-12-2011 05:42 PM
ugh...GoldWing on a tow truck bikergoth Goldwing Technical Forum 2 07-20-2008 08:52 PM
Ugly with a Capital UGH! UbarW General Motorcycle Discussion Forum 16 04-17-2007 06:06 AM
No Clutch....ugh.. Jim Goldwing Technical Forum 18 08-12-2005 12:55 PM
