No spark suddenly - Steve Saunders Goldwing Forums
  • 1 Post By rayjoe
post #1 of 8 (permalink) Old 09-02-2018, 09:55 PM Thread Starter
hutchings's Avatar
Model: gl1100i
No spark suddenly
Guys i was chasing a long time 6k full throttle miss. Replaced coils. Now no spark. Run switch good. 12v at coils. Coils test good. Ground good.
I did something to cause neither coil to fire.
No analog meter to trigger sensor. Timing belt not very old.
Been workin an now stumped. Am stuck
Thanks guys
hutchings is offline
post #2 of 8 (permalink) Old 09-02-2018, 10:00 PM Thread Starter
hutchings's Avatar
Model: gl1100i
Ps
Crank voltage 11v
post #3 of 8 (permalink) Old 09-02-2018, 10:23 PM
rayjoe's Avatar
Try putting the old coils back on. In the process you may find that wire/connection you missed.
Good luck,
Rayjoe
redwing52 likes this.
rayjoe is offline
post #4 of 8 (permalink) Old 09-03-2018, 12:32 AM
I would tend to agree with Rayjoe. When I do something and it does worse I usually undo. That is a good clue.
redwing52 is offline
post #5 of 8 (permalink) Old 09-03-2018, 04:00 PM
OldSchool_IsCool's Avatar
Year: 1982
Model: Interstate
To get a coil to throw a spark, you need not only 12v at the black/white wire, you also need the yellow and blue wires to toggle to ground. Pull off the yellow and/or blue wires, connect a jumper wire to the coil terminal. Do you get a spark as you touch the jumper wire to ground then pull it off?
Bruce
Current Bikes:
74 CB750 K4
77 CB550 K3
82 CM250C
Past Bikes:
What?? SELL a bike??
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
PGR since 2011
OldSchool_IsCool is offline
post #6 of 8 (permalink) Old 09-04-2018, 11:43 AM Thread Starter
hutchings's Avatar
Model: gl1100i
Did try put old back on.
Next trying jumper wire at coil.
post #7 of 8 (permalink) Old 09-05-2018, 03:30 PM
rayjoe's Avatar
No spark
Let us know what you find?
Rayjoe
rayjoe is offline
post #8 of 8 (permalink) Old 09-05-2018, 05:34 PM Thread Starter
hutchings's Avatar
Model: gl1100i
So no spark when ground blue or yellow.
Battery voltage not really 11.
Its a gel cell and prob 4 yrs old. This engine cranks easy but ...... I am thinking new battery time anyway. Save getting stranded another day.
I will keep you posted.
Thanks for holding my hand for a bit. I was getting like my battery. Cranky with low volts.
GL1000 No Spark or almost no spark WingForChrist Goldwing Technical Forum 8 07-29-2013 11:09 AM
Suddenly no power to my travel computer. Fuse somewhere? poolguy Goldwing Technical Forum 8 11-03-2011 10:31 AM
spark no spark mark3 Goldwing Technical Forum 14 06-30-2008 07:41 AM
gl1000 weak spark, no spark tmoerbe Goldwing Technical Forum 9 01-07-2008 08:30 PM
Replaced the Spark Unit ... still no spark ttexastim Goldwing Technical Forum 14 06-06-2006 04:15 AM
