84' GL1200 STANDARD - lower gauge switch mystery - Steve Saunders Goldwing Forums
 3Likes
  • 1 Post By glhonda
  • 1 Post By glhonda
  • 1 Post By macvit7906
post #1 of 9 (permalink) Old 09-03-2018, 09:15 PM Thread Starter
Year: 1984
Model: Gl1200 Standard
Hi All,
Putting a GL1200 Standard back together. Full restore.
I've come across something that has stumped me and I can't find any info out there. For those of you who own or know about the 1984 STANDARD models:
My sub wire harness, (Thermostat, temp sending, pressure switch wires) that attaches up to the main wiring harness, looks to have some type of switch soldered in place (by PO) instead of the regular thermostat plug. The switch runs up and connects into the plastic piece covering the handlebars below the gauges, so you can switch whatever it is on and off. I have attached pictures.
Questions:
What is this switch?!?
Should I keep it or solder the original thermostat plug back in place?
Thanks for you expertise!
macvit7906 is offline
post #2 of 9 (permalink) Old 09-03-2018, 09:23 PM
glhonda's Avatar
Someone has wired in an auxiliary switch to operate the cooling fan. If the thermostatic switch is functioning correct, eliminate this setup. If not, you'll probably need it to operate the fan.
Bike...and Dennis likes this.
glhonda is offline
post #3 of 9 (permalink) Old 09-03-2018, 10:10 PM
AaronzDad's Avatar
Year: 1987
Model: GL1200A Aspencade
Yup, fan switch thermostat went bad and instead of replacing it they just put in a switch.
Same thing happened on my '87 Aspencade but I found a new thermostat sensor on eBay for a few bucks.
Might as well put in the new sensor since you already have it all apart.
AaronzDad is offline
post #4 of 9 (permalink) Old 09-03-2018, 10:14 PM
AaronzDad's Avatar
Year: 1987
post #5 of 9 (permalink) Old 09-03-2018, 11:03 PM
glhonda's Avatar
Be careful about buying thermo switches by sellers who don't give operating ranges. A lot of aftermarket switches operate 10-15 degrees below factory specs. It may sound good if you have overheating problems, but the fan will run too often, and too long. The engine temp is critical for best oil protection characteristics.
glhonda is offline
post #6 of 9 (permalink) Old 09-04-2018, 12:14 AM
I couldn't find one that actually fit the plug and I did a LOT of looking. OEM works correctly, of course. I ended up cleaning the original sensor and it started working again.
post #7 of 9 (permalink) Old 09-04-2018, 12:35 AM
AaronzDad's Avatar
Year: 1987
That's strange, I found several online suppliers of both new and used sensors when I was working on my bike a couple years ago.
I did a quick search on eBay for "GL1200 fan switch thermostat" and came up with a handful.
However I do recall some people saying the "new" ones had the wrong thread size. I bought one from a salvage yard so it went right in.
post #8 of 9 (permalink) Old 09-04-2018, 01:16 AM
The one that had the right threads wouldn't fit the plug on the wire harness. Never got to check the temp range because I won't cut up a wire harness to accommodate the wrong part.
post #9 of 9 (permalink) Old 09-04-2018, 01:29 PM Thread Starter
Year: 1984
Thanks All,
Already installed a new OEM thermostat and Thermo switch so good to go here.
84 GL1200 Standard ignition switch MaloGL1200Standard New Members Introduction Forum 8 12-11-2015 05:48 AM
84 GL1200 lean or rich?? 4000 rpm mystery JWineland Goldwing Technical Forum 5 09-15-2012 10:00 PM
84 Honda Standard fan switch Winesap7 Goldwing Technical Forum 2 07-19-2011 07:41 AM
Will 85,86 lower fairing fit 84? Or just 84,85? newbiker For Sale/Wanted Forum 2 12-07-2007 06:29 AM
