GL1800: Digital Audio Unit Always 'On' - Page 2 - Steve Saunders Goldwing Forums
post #11 of 13 (permalink) Old 09-24-2018, 10:49 AM
briese's Avatar
Originally Posted by ALEX BERECZKY View Post
Update: I'm happy to say that I have Solved this problem of Constant Power Draw!
I re-routed the Power Wire to a (Aux) Relay-Power Supply, and now the Audio Unit only operates when the bike is running. I randomly selected a 2 Amp fuse to control the circuit. I've tested it for a week now, no problems.
The Power Wire is one of 2 Red Wires going into the White Connector under the Seat... As you look at the connector (from the Audio Side) it is in the top right corner.
One question, which side of the connector did you use to reroute power? The digital audio player side or the bike side.
I'd be more prone to remove the wire from the digital audio power plug than the motorcycle plug. But that is me.
1998 - GL1500 w/175,000 miles
2003 - GL1800 w/106,000 miles
briese is offline
post #12 of 13 (permalink) Old 09-24-2018, 12:56 PM Thread Starter
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
I cut the wire on the side of the plug nearest the Digital Audio Player... then re-routed same side to the Aux Relay Power Supply.
Put differently, the Aux Relay Power Supply only feeds the Audio Player (not the bike's radio)
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #13 of 13 (permalink) Old 09-24-2018, 01:23 PM
briese's Avatar
That would have been my choice too. Thanks.
briese is offline
iSimple IS31 Review (Audio Input Unit) on GL1500 Dannyboy1949 Goldwing Technical Forum 2 05-17-2014 11:55 AM
Defective Audio Unit??? GL1800 AA-7 (2007 Model) Machine Man Goldwing Technical Forum 3 07-18-2012 05:21 PM
Audio Unit GL1800 airbag model GeGe Goldwing Technical Forum 4 11-14-2009 03:51 PM
GL1800 Audio Unit. Wing-Rider General Motorcycle Discussion Forum 2 12-17-2008 11:23 PM
