Gl1500 vague steering ,front end wonder at take off - Steve Saunders Goldwing Forums
post #1 of 15 (permalink) Old 09-23-2018, 11:14 PM Thread Starter
Robbie G's Avatar
Year: 1994
Model: GL1500 SE
My 1994 Honda GL 1500 se, very low miles, new tires.....when taking off from dead stop and immediately turning, the sreering seems unstable and vauge untill you throttle away, front tire hunts around seems to be flexing...Is this normal for these bikes and would a fork brace help ?
I do have race tech springs now and th front end is good once you are cruising along, but when just taking off, front end just feels vauge. Normal for these bikes ?
Robbie G is offline
post #2 of 15 (permalink) Old 09-23-2018, 11:40 PM
Air up the tires.
post #3 of 15 (permalink) Old 09-24-2018, 03:18 AM
the 1500s severely need a Fork Brace.
does your bike have one on it?
if not, get one,
Super Brace or equivalent.
that and keeping the tires at 44 psi, makes a whole world of difference in how it handles.
you would not believe it is the same bike.
NASR 12 in Galena, IL
post #4 of 15 (permalink) Old 09-24-2018, 10:15 AM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
Also, if the PSI is Low on the rear shocks, it will cause the front end to wander.
Putting Progressive Rears on is the BEST... I always run mine at 90psi (eg The Max for them), and can notice a huge (detrimental) difference if I drop the pressure down to 70psi; this is for Solo riding BTW.
The stock honda rear shocks can only go up to 50psi, as I recall.
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #5 of 15 (permalink) Old 09-24-2018, 11:40 AM
DBohrer's Avatar
Model: '99 Gold Wing SE
Brand of tires...?
What air pressure front/rear..?
Fork Braces are a good enhancement for low speed stability.
Has any work been done recently on the front end. Such as forks removed/replaced etc.
If so, were bolts/fasteners torqued correctly.
DBohrer is offline
post #6 of 15 (permalink) Old 09-24-2018, 11:42 AM
DBohrer's Avatar
That would be 57 psi........!!
DBohrer is offline
post #7 of 15 (permalink) Old 09-24-2018, 08:07 PM Thread Starter
Robbie G's Avatar
Year: 1994
Model: GL1500 SE
Thanks for all your replies and suggestions everyone. I checked my front air pressure and it had dropped down to 28 psi! I pumped it up to 40, took it for a ride, and was just amazed how the handling and stability at slow speeds improved. I guess this bike is very sensitive to front tire air pressure !
Robbie G is offline
post #8 of 15 (permalink) Old 09-24-2018, 08:11 PM
I would push it to 44 psi, I know, you think it is too much, but it is not.
post #9 of 15 (permalink) Old 09-25-2018, 08:13 PM
tlbranth's Avatar
Year: 1999, 1975
Model: GL1500SE GL1000
if not, get one,
I put a fork brace on my '99 and couldn't tell the difference. Do check tire pressure though.
flylow likes this.
Terry
Don't own a Vanagon.
Don't work at Boeing.
Life is good.
1970 CB750
1975 GL1000
1999 GL1500 SE
2002 VT750
tlbranth is offline
post #10 of 15 (permalink) Old 09-27-2018, 08:07 AM
joe in calif's Avatar
Tire air pressure makes a difference in the way they handle. You should check the air pressure at least once a week, best to check before every ride. You could have a slow leak and not know it
A NEW START ON 1/20/2017
joe in calif is offline
taking injection system off to take off heads jeffro1954 Goldwing Technical Forum 2 09-27-2014 01:47 PM
I have a vague recollection of miroku800 Goldwing Technical Forum 12 10-13-2010 07:25 AM
hesitation on low end speed on take off oldguy1944 Goldwing Technical Forum 8 09-15-2010 09:07 AM
clymers manual vague zimmerleemark Goldwing Technical Forum 10 05-09-2007 08:28 PM
Vague Front End. Curlytops Goldwing Technical Forum 7 04-10-2007 08:01 AM
