91 1500 Starting question. - Steve Saunders Goldwing Forums
 13Likes
post #1 of 18 (permalink) Old 11-19-2018, 01:45 PM Thread Starter
Guru
Hatchetman's Avatar
Got my 91 1500 home & went to start it this morning. Very cold out but thats not the issue. While cranking it will not fire. As soon as I let off the starter button it does. Had this issue once in a truck but not on a bike. Is there a relay or something I have to hunt down???
Hatchetman is offline
post #2 of 18 (permalink) Old 11-19-2018, 02:04 PM
BLUTHUNDR31's Avatar
Seems to me like this issue came up a while back, and IIRC, the problem was solved by taking the "clam-shell" for the starter button apart, and cleaning the contacts there. The fuel pump on your bike gets a signal from the start button being pushed, and if the contacts are "off" a bit, the bike has the issue you are experiencing.
There are other possibilities too, , but this one was the most recent I believe.
Hatchetman likes this.
BLUTHUNDR31 is offline
post #3 of 18 (permalink) Old 11-19-2018, 02:08 PM
Alan_Hepburn's Avatar
Year: 1994
Model: GL1500SE
That is the classic symptom of a low battery - there's enough juice to spin the starter, but not enough to fire the plugs at the same time. As soon as the starter is released from the circuit there's enough power to fire a plug, and the engine starts. The solution is to replace the battery, and make sure it's fully charged by using a tender.
Alan Hepburn
1994 GL1500SE with a California Sidecar
San Jose, Ca
Alan_Hepburn is offline
post #4 of 18 (permalink) Old 11-19-2018, 02:25 PM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
If the problem can not be solved, you may want to try my solution.
https://www.goldwingfacts.com/forums...on-solved.html
Erdeniz Umman is offline
post #5 of 18 (permalink) Old 11-19-2018, 03:05 PM
that is a Classic symptom of a Wet Cell battery that is near end of life.
buy an AGM battery with 320 CCA or more, and the engine will start before you can get your finger off the button.
I bought the Big Crank battery last time,
from this company.
https://www.batterymart.com/p-Big-Cr...L-Battery.html
Cold Cranking Amps: 340 CCA
all of the GL1500 compatible batteries in this link
https://www.batterymart.com/POWERSPO...1500-MN5-020AH
NASR 12 in Galena, IL
post #6 of 18 (permalink) Old 11-19-2018, 03:13 PM
Year: 1978
Model: GL1000
Send a message via Skype™ to torontoGL78
Try with an other strong battery. Signs of low or about to die battery
1978 GL1000 - Stock
1977CB550 - Stock
1974 CB550K - Stock
1978 CB750 - Stock
2009 HD Road King Classic
torontoGL78 is offline
post #7 of 18 (permalink) Old 11-19-2018, 05:07 PM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
For as long as I recall, I've heard that it's best on a 1500 to only crank the engine ~2-3 times, then get off the starter button... At which point the engine tends to fire up better than if you stay on the starter for longer.
This has worked great for me, especially in colder weather.
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #8 of 18 (permalink) Old 11-19-2018, 05:44 PM
from this company.
Put an AGM in the bike and it will start before you push the button.
AZgl1800 and DBohrer like this.
redwing52 is offline
post #9 of 18 (permalink) Old 11-19-2018, 08:42 PM
post #10 of 18 (permalink) Old 11-19-2018, 10:03 PM
gumbyred's Avatar
Model: 2006 Level 2 Gold Wing
Define cold in your neck of the woods. If it is too cold to ride, I leave it alone till it is warm enough. A strong., fully charged A.G.M. battery with clean, and tight connections is a must to start a Gold Wing in cooler weather. If the spark plugs haven't been changed, and correctly gapped in awhile, that could also be part of the problem.
gumbyred
gumbyred is offline
My wing is starting to have trouble starting up '84 Gl1200 I crimsonwing Goldwing Technical Forum 15 06-29-2017 02:50 PM
Question regarding mechanical sound on '91 Aspencade leonardthefast Goldwing Technical Forum 13 09-11-2011 08:00 PM
poor starting, low coolant level - 91 GL1500I w/42k miles tallyho Goldwing Technical Forum 13 03-16-2009 12:52 PM
Starting 91 GL1500 after 18 months tallyho Goldwing Technical Forum 16 01-18-2009 07:48 PM
Fuses blowing on a 91 wing asp 1500 oldiebutgoodie Goldwing Technical Forum 1 10-31-2006 12:57 AM
