Power loss and almost died: 300+ mile trip 1997 GL1500 - Page 2 - Steve Saunders Goldwing Forums
 4Likes
post #11 of 16 (permalink) Old 11-25-2018, 11:32 PM
Originally Posted by tlbranth View Post
Hmmmmm!
Actually, after the first incident last year I put in a new filter and checked the old. There was nothing in it. Good idea though.
Might be the screen in the tank?????????
redwing52 is offline
post #12 of 16 (permalink) Old 11-26-2018, 10:45 AM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
Originally Posted by OnaWingAndaPrayer View Post
Perhaps water, but I would also look at the vacuum lines and the vacuum fuel shutoff valve.
+1... If it happens again, then by-pass the Fuel Shutoff Valve... Those things seem to always go bad
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
post #13 of 16 (permalink) Old 11-26-2018, 11:39 AM
tlbranth's Avatar
Year: 1999, 1975
Model: GL1500SE GL1000
You mean the petcock? I would expect that to just plumb fail. Or could it screw up sporadically?
Terry
Don't own a Vanagon.
Don't work at Boeing.
Life is good.
1970 CB750
1975 GL1000
1999 GL1500 SE
2002 VT750
tlbranth is offline
post #14 of 16 (permalink) Old 11-26-2018, 01:20 PM
...yes "Petcock". They can "partially" fail, or "totally" fail.
The internal rubber diaphragm goes bad, and/or the vacuum source (to operate it) is bad/weak/intermittent.
They just suck, really... cause more harm than good
I void warranties
KJ6QFZ
Dark Side #590
post #15 of 16 (permalink) Old 11-26-2018, 02:59 PM
personally, that should have been an electric fuel shutoff valve from the factory.
because it will not open until the engine creates vacuum.
that wastes the first two revolutions of the engine.
NASR 12 in Galena, IL
post #16 of 16 (permalink) Old 11-26-2018, 06:57 PM
tlbranth's Avatar
Year: 1999, 1975
Well I did pick up a repair kit some time ago. Maybe I should just put it on.
Terry
Life is good.
1970 CB750
1975 GL1000
1999 GL1500 SE
2002 VT750
tlbranth is offline
GL1500 - 300,000 mile rebuild GLGREZMONKI Reference and FAQ Forum 104 05-14-2016 07:53 AM
GL1000 Intermittent Power Loss, I am at a Loss here. Rider15 Goldwing Technical Forum 4 07-20-2013 10:45 PM
$300 for HF full bke lift! $300 savings! Chromo General Motorcycle Discussion Forum 9 11-29-2012 08:22 PM
"81 1100 power loss/ mpg loss Please help! Thank You! gunnarthegreat Goldwing Technical Forum 8 08-12-2010 12:22 AM
Hunting at Tick-over and loss of power on full throttle GL1500 clippy Goldwing Technical Forum 29 06-07-2008 05:17 AM
