1986 Honda GW Aspencade - Timing and Marks - Steve Saunders Goldwing Forums
post #1 of 12 (permalink) Old 11-25-2018, 07:37 AM Thread Starter
JayPoorJay's Avatar
I've posted more of an INTRO thread here... I am SUPER grateful for all of the attention, support, warnings and encouragement >>>> forward then! Thank you and deep bow.
So, I've checked the timing - I got a couple different results and I'm hoping folks will help me out and get me on the right track... Between T and 1. If you look at the photos the Cam gears are not spot spot on,,,, which leaves me to guess that I am in the right neighborhood. (If you all tell me thats what I need to do) I will spin the engine again in the next days and get the markings on CAM gears to line up EXACT (take better pictures) and re-visit you good people. The photos are TOUGH because its hard to know if the angle is adequate for right viewing. Anyways - this is what i got
https://imgur.com/KzvvRXw
https://imgur.com/rFvIXuS
https://imgur.com/jxpvZRi
https://imgur.com/1CJ0OUy
https://imgur.com/znoyKWp
https://imgur.com/0p2Lb9M
Note: I think I missed taking a picture or TWO that I was needing to take! I will go back (without getting dirty today) and take them! This is what I have for now. What say you?
I have also removed the Carbs. Things did not LOOK as bad as I thought but 2 of the small (slow) jets were completely clogged and ONE was literally hanging by 2-3 threads. It was soooo loose I could turn it out by hand. All that to say she was still running really rough after draining out and changing gas.
I haven't figured out the cooling problem and no fan when hot. Any straight forward tests and troubleshooting is welcomed.
I have my CLYMER manual - have the HAYNES coming. Looks good but doesn't give much on the cooling electrics - unless I missed something. I've noticed a book on Ebay that seems to deal specifically with electrics - around $50bucks - worth getting? IMPORTANT QUESTION --- WILL THERE BE A BIG DIFFERENCE BETWEEN THE 87 AND 86 BOOK. I JUST NOTICED THIS ONE ON EBAY FOR $25!!! I WON'T GET IT IF FOLKS SAY THAT THE DIFFERENCES ARE HUGE - hopefully someone here won't see it and snag it out from under me, lol
Again, many thanks - see ya on the flip side!
JayPoorJay is offline
post #2 of 12 (permalink) Old 11-25-2018, 07:59 AM
Pure Texas's Avatar
Make: Goldwing
1968 Kawasaki Avenger
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
Pure Texas is offline
post #3 of 12 (permalink) Old 11-25-2018, 08:06 AM Thread Starter
JayPoorJay's Avatar
Originally Posted by Pure Texas View Post
You really need to find the plug that screws into the timing hole for exact timing timing inspection plug': Honda Code 0630681 and part number 07999-3710001.
I'll check the part numbers but,,,, which plug? I had been seeing folks checking timing in lots of areas on-line by eye a the hole and lining up the CAM gears... Is it impossible that way?
post #4 of 12 (permalink) Old 11-25-2018, 08:41 AM
Pure Texas's Avatar
Make: Goldwing
1969 H1 Kawasaki
1975 1000
1985 LTD
1982 1100,STANDARD
1991 ST 1100
1991 SE Goldwing.
1995 BMW R 1100RS
post #5 of 12 (permalink) Old 11-25-2018, 09:25 AM
The inspection plug is for checking ignition timing, can't change it so why worry about it? If you have the T mark lined up with the mark on the case and the cam marks are less than 1/2 tooth off you are not going to get it any closer.
post #6 of 12 (permalink) Old 11-25-2018, 10:07 AM
You covered this in the other thread. Why re-post it?
post #7 of 12 (permalink) Old 11-25-2018, 12:23 PM Thread Starter
JayPoorJay's Avatar
Dennis! Why ask Why? But since you did,,, its for new eyes AND so,,, when another does a google search they can find something specific to their search - because of the specifics in the title.
Anyways
I have some new pictures here and things look farther off than the first. Let me know what ya make of these... Dave,,, thanks for your comments on the other/older unspecified thread AND for the assurance in letting me know that one can only get so,,,, close... Noted
I think my important thread will be the one I need to make for the carbs. For a sec i thought i had a timing problem causing my bad running... Im thinking it might and must be a Carb thing. Again, thanks Dave.
post #8 of 12 (permalink) Old 11-25-2018, 12:54 PM
Again, your cam timing IS NOT going to get any closer.
post #9 of 12 (permalink) Old 11-25-2018, 04:34 PM Thread Starter
JayPoorJay's Avatar
Got ya. Thanks.
post #10 of 12 (permalink) Old 11-26-2018, 03:24 PM
" new eyes " ???
we all look at New Posts
Timing marks beachbuddy0253 Goldwing Technical Forum 23 03-10-2009 01:25 PM
gl1000 timing marks tmoerbe Goldwing Technical Forum 1 05-10-2008 04:30 PM
timing marks racejunky Goldwing Technical Forum 6 12-22-2007 04:57 PM
Timing Marks jimjim Goldwing Technical Forum 3 12-13-2005 09:50 PM
77 GL1000 My timing marks arent like in the book!!! Wingcommander Goldwing Technical Forum 9 11-13-2005 04:54 PM
