1984 GL1200 Standard - new issue - Steve Saunders Goldwing Forums
 7Likes
post #1 of 31 (permalink) Old 11-26-2018, 01:26 PM Thread Starter
Year: 1984
Model: Gl1200 Standard
Hi All, need some help again.
Decided to take a little ride yesterday, went about 6 miles. She no longer charges properly, even with a new stator and reg/rec. Battery died and I was able to get a jump and charged enough to get back home.
While running, hook up my voltmeter, battery very slowly drains or stays the same, no longer seeing 14+ volts while running. When running, runs like a goldwing should, just a bit of popping through the carbs between 1000-2000 rpms.
The first few start ups after rebuild, was seeing at least 14V while running, so she was charging great. Stator, reg/rec, and battery are brand new.
I'm running 10-40w high quality oil with a little bit of marvel mystery oil. I may have about 1/4 quart too much oil in there - was using the marvel to get the engine nice and clean after 20 years of not running, could that have affected stator?
Stator: https://www.randakks.com/upgraded-st...nd-gl1201.html
reg/rec: https://www.randakks.com/regulator-r...00-gl1000.html
It could possibly be a loose connection but doubtful , I'll go over it more thoroughly when I have time.
Any initial ideas/testing procedure/things I could check that might be cause her to randomly stop charging?
macvit7906 is offline
post #2 of 31 (permalink) Old 11-26-2018, 01:45 PM
I would go back to basics. Check the 3 wires that come from the stator for voltage. Make sure the connections are all good. Troubleshoot it just like you did originally when it quit charging. Unfortunately even new parts can fail prematurely.
redwing52 is offline
post #3 of 31 (permalink) Old 11-26-2018, 01:53 PM
Check all the connectors from the stator to the regulator for signs of heat. Also recheck the battery and regulator grounds.
Unfortunately, its pretty common for aftermarket stators to last that long. I thought Randall's stuff was better, but maybe not.
post #4 of 31 (permalink) Old 11-26-2018, 01:58 PM
Guru
Hatchetman's Avatar
I agree with the other comment. Pull the Left side cover & check those 3 yellow wires at the plug. The plug melts & your charging stops. Cut the plug out & sodder them together. cover with heat shrink. Wires do not matter how they are re joined. as long as all 3 are reconnected to the other 3.
Hatchetman is offline
post #5 of 31 (permalink) Old 11-26-2018, 04:43 PM Thread Starter
Year: 1984
I'll check the wires more thoroughly this week and let you know my findings.
Really bummed! Ran great for a week.
post #6 of 31 (permalink) Old 11-26-2018, 07:56 PM
tlbranth's Avatar
Year: 1999, 1975
Model: GL1500SE GL1000
I've had 3 melted connectors, one after the other that resulted in your symptoms. I finally chucked all the power connectors and installed 30 amp Anderson Power Pole connectors. They don't melt.
AZgl1800 and Hatchetman like this.
Terry
Don't own a Vanagon.
Don't work at Boeing.
Life is good.
1970 CB750
1975 GL1000
1999 GL1500 SE
2002 VT750
tlbranth is offline
post #7 of 31 (permalink) Old 11-26-2018, 08:01 PM
A friend had an '84 with wire nuts replacing that plug. He didn't know how long they had been there but they were still there when he sold the bike after some 20 years of ownership.
post #8 of 31 (permalink) Old 11-27-2018, 10:52 AM
Model: 1993 GL 1500
Those wires run up to the reg/ref and get burned up under the false tank also, check everything all the way to the reg. The new reg/ref comes with wires that look to small for the load. There is a lot of heat around the reg. If the stator has the right voltage on each leg. with the rpm's up at about 2000 than it is ok. next check the wiring.
Jerry Burns is offline
post #9 of 31 (permalink) Old 11-27-2018, 05:05 PM Thread Starter
Year: 1984
Thanks Jerry,
Where should I be connecting my voltmeter to in order to check if the stator has the correct voltage at each leg? The three yellow wires, one at a time? What kind of voltage should I see?
post #10 of 31 (permalink) Old 11-27-2018, 05:19 PM
Originally Posted by macvit7906 View Post
Thanks Jerry,
Assign any of the wires a letter A-B-C in any order. Put the two probes of your voltmeter from A to B then A to C then B to C.
The engine should be running at about 3,000 RPM and the plug unplugged or wires cut if hard wired. You are testing the 3 wires from the stator (engine side) You should see in excess of 50 volts AC. Again that is 50 volts AC. (VAC) That is for all 3 tests. (all 3 legs of the stator))
Jerry Burns likes this.
1984 GL 1200 Standard Starter issue suz1100 Goldwing Technical Forum 20 10-11-2015 09:45 PM
Hello...and 1984 GL1200 Standard? winston New Members Introduction Forum 19 11-10-2006 08:17 AM
Shopping for Info on parts for 1984 GL1200 standard cjswings General Motorcycle Discussion Forum 1 09-29-2006 11:22 PM
Needed: 1984 GL1200 Standard Headlight ears and Bucket cjswings For Sale/Wanted Forum 0 09-28-2006 12:02 PM
1984 Gl1200 Standard on Ebay ringo00 General Motorcycle Discussion Forum 2 02-08-2006 10:27 AM
