Front wheel question - Steve Saunders Goldwing Forums
post #1 of 3 (permalink) Old 12-02-2018, 09:42 PM Thread Starter
Part of living and riding in Australia is the constant threat of striking a kangaroo. I had the first experience of striking one on my new 2002 Gl1800 recently and have a question in regards to the damage.
While the damage to the bike was very minimal as the front wheel took the impact it did manage to break off the pulser ring located on the right side of the wheel, part number 44515-MCA-971. The ABS light also is now flashing.
My question is what is the purpose of the pulser ring and is it part of the ABS?
Thank you for your help.
jeffthechef is offline
post #2 of 3 (permalink) Old 12-02-2018, 10:14 PM
Yes, it is what signals the ABS. There's one on each wheel.
Please fill in your profile.
post #3 of 3 (permalink) Old 12-03-2018, 02:40 AM
Erdeniz Umman's Avatar
Model: GL1500SE Euro Spec
In an ABS system there is a magnetic pickup and a ring like that on each wheel. In one rotation of the wheel, magnetic signals are generated depending on the number of the slots on the ring (more accurate than on most of the cars).
When the ABS control unit can not receive a continuous signal, it thinks that the wheel is locked up and adjusts the brake pressure to gain the wheel control again.
Actually, in modern bikes ABS doesn't wait to react until the wheel slips. It continuously controls the brake pressures on each wheel according to their rotation speeds as you apply the brake.
Erdeniz Umman is offline
84 Aspencade front wheel/axle binding when torqued to spec.. wheel bearings distorted Linus Goldwing Technical Forum 10 08-01-2018 12:29 PM
Question about front wheel bearings 4evermetric Goldwing Technical Forum 11 04-18-2009 11:22 AM
1800 front wheel question Phat Chance Goldwing Technical Forum 4 06-27-2008 04:03 PM
Front wheel removal question. 4evermetric Goldwing Technical Forum 4 06-09-2008 06:45 PM
84 Aspencade front wheel installation question shmolous Goldwing Technical Forum 3 03-03-2008 02:57 PM
