GL 1500 Front Wheel Noise - Page 2 - Steve Saunders Goldwing Forums
 4Likes
post #11 of 19 (permalink) Old 12-06-2018, 12:54 PM
Originally Posted by eastkytriker View Post
That makes sense. I had the forks off and rebuilt them. Had the noise before but it seems to be getting worse. I left the pinch bolts loose on the bottom held the front brakes and gave it some good bounces, Is there a better way to align them.
Yes. Loosen everything below the upper tree bolt, including the fender bolts, and don't hold the brake. Put the tire against a solid surface and compress the forks a few times.
Then tighten everything, starting with the axle pinch bolts and work your way up.
post #12 of 19 (permalink) Old 12-06-2018, 04:49 PM Thread Starter
Year: 1990 1500 Goldwing/Motortrike Florida trike 2008 1800 Goldwing/Roadsmith Kentucky Trike
Originally Posted by ALEX BERECZKY View Post
+1... The left brake caliper is probably hitting the Bolts on the brake rotor. Easy fix:
Steps:
1) Loosen Axle bolt.
2) Loosen all (4) pinch bolts.
3) Use (.020") shim to set gap, between left brake caliper (not the pad) and the brake rotor... or just verify Same Gap both sides of left caliper.
4) Tighten (2) pinch bolts on Left side.
5) Tighten Axle Bolt
6) Tighten (2) pinch bolts on Right side
Thanks for info, I will try this tomorrow. At what point do you set clearance on right caliper
eastkytriker is offline
post #13 of 19 (permalink) Old 12-06-2018, 04:52 PM Thread Starter
Thanks I will take a look at doing this tomorrow. I'll let you know the outcome.
post #14 of 19 (permalink) Old 12-06-2018, 05:15 PM
The right side clearance is controlled by the axle nut and is not adjustable.
On the left side you're setting the clearance between the caliper mounting bracket "not the caliper" and the brake rotor.
Ken Bergen is online now
post #15 of 19 (permalink) Old 12-06-2018, 05:33 PM
CrystalPistol's Avatar
Ken's post above.
...(Candy Spectra Red )
CrystalPistol is offline
post #16 of 19 (permalink) Old 12-06-2018, 06:27 PM Thread Starter
Thanks Ken, I will give it a try tomorrow.
post #17 of 19 (permalink) Old 12-07-2018, 10:29 AM Thread Starter
Thank everyone for your replies, I realigned the forks and wheel by different method and noise is gone.
CrystalPistol likes this.
post #18 of 19 (permalink) Old 12-07-2018, 10:34 AM
What "different method"?
post #19 of 19 (permalink) Old 12-07-2018, 10:46 AM Thread Starter
I used the line on the axle on left side to line with edge of fork, tightened clamp bolts then tightened axle bolt. bounced it up and down then tightened right side clamp bolts and noise was gone.
1500 noise from front wheel t15dja Goldwing Technical Forum 15 09-25-2013 05:55 PM
GL1500 front wheel noise Saddle Time Goldwing Technical Forum 7 10-06-2012 05:36 PM
Noise, noise noise in my GL1100 headset. rb7632 Goldwing Technical Forum 11 10-10-2009 04:42 PM
GL1200A Front wheel noise kelandsmith Goldwing Technical Forum 8 05-13-2009 09:28 PM
Noise when front wheel rotates 1MOR Goldwing Technical Forum 5 08-01-2008 10:50 AM
