Any help will do, not sure which forum to look at - Page 4 - Steve Saunders Goldwing Forums
 11Likes
post #31 of 41 (permalink) Old 12-13-2018, 11:31 AM Thread Starter
Year: 1984
Make: aspencade
Model: GL1200
The list is endless. And often OEM costs no more than the junk.
In the case of the stator, though, OEM isn't available and the aftermarket stators often last for minutes, once running. Let's hope your stator isn't an issue.
I see that makes sense, and yea that wouldn't be good, I am sure we will find out today hopefully
bkindred91 is offline
post #32 of 41 (permalink) Old 12-13-2018, 02:11 PM
gumbyred's Avatar
Model: 2006 Level 2 Gold Wing
We have some people here who enjoy working on Gold Wings. It is therapy for them. They can turn out some real good bikes. If you are mechanically inclined and like to do your own work,, it might be a good project. You could not afford to pay someone else $70.00 an hour, or more to get it running though. Especially one that has been left out in the elements.
gumbyred
limpy45 likes this.
gumbyred is offline
post #33 of 41 (permalink) Old 12-13-2018, 06:36 PM
The bike is rough and not all there. The battery took a surface charge pretty quickly but bkindred brought only one key...and of course the ignition has been changed, so he needed both keys.
The thing that concerns me the most is, there was a can of paint where the air cleaner was supposed to be. If someone has been using that as a starting fluid, I fear the carbs will be unusable.
post #34 of 41 (permalink) Old 12-13-2018, 07:02 PM
Why? If someone did spray paint in the intake it would only be in the carb bores and won't hurt anything. Most carb cleaner sprays are lacquer thinner so should melt it right out.
post #35 of 41 (permalink) Old 12-13-2018, 07:05 PM
rayjoe's Avatar
goldwing
Hey bike and Dennis. Really nice of you to lend a hand! Sounds like he has got his work cut out for him.
At least he didn't pay too much for it.
Rayjoe
siouxindian and limpy45 like this.
rayjoe is offline
post #36 of 41 (permalink) Old 12-14-2018, 11:08 AM Thread Starter
Year: 1984
Make: aspencade
Model: GL1200
Rayjoe
I am for sure very grateful, and gained a lot more insight than what I had going into this, I am looking forward in seeing how far along I can go with this.
post #37 of 41 (permalink) Old 12-14-2018, 11:44 AM
Let me know when you are going to work on it again.
post #38 of 41 (permalink) Old 12-14-2018, 03:07 PM
Year: 1982
Model: Aspencade
Tell me more, did the engine turn over ? Without battery you can check by putting it in gear and pushing it a bit to tell if the motor will move. That will let you know the major motor components are okay. As in no rust has set up in cylinder or valve train. Always good to check first,(dont ask)
Did you check the group of wires under the 'tank' cover ? My wing was stored outside and squirrels got some wires. You are correct this site has valuable info for wing owners.
good luck and keep us updated.
limpy45 likes this.
Terrelt
Location Plano, Texas
1982 Aspencade bringing back to life.
1986 Suzuki GS850
2005 Kawasaki Vulcan 500
Terrelt is offline
post #39 of 41 (permalink) Old 12-14-2018, 07:44 PM
gumbyred's Avatar
Whoever parked that bike outside, knew something about the bike that you haven`t discovered yet,
gumbyred is offline
post #40 of 41 (permalink) Old 12-14-2018, 09:54 PM
glhonda's Avatar
Plus one. They parked it for a reason.........
glhonda is offline
Forum question and not sure where to go with it youngnbald Test Forum 10 07-08-2013 10:09 AM
Not sure which one red_bike General Motorcycle Discussion Forum 13 12-10-2011 04:17 PM
NASSIR 3 DATE POLL ... LOOK LOOK LOOK wexy Events 192 11-01-2009 10:37 PM
Do you need special antifreeze? Not sure about that. newbiker Goldwing Technical Forum 20 06-02-2008 11:25 PM
I can't say for sure if it's true,,, But I sure hope so!!! Goldwinger Miscellaneous Forum 0 05-14-2006 08:27 PM
