Progressive Air Shocks - Steve Saunders Goldwing Forums
 6Likes
  • 1 Post By McFirefighter
  • 2 Post By Bellboy40
  • 1 Post By CrystalPistol
  • 2 Post By haroldaugustine
post #1 of 6 (permalink) Old 12-16-2018, 04:43 AM Thread Starter
McFirefighter's Avatar
Year: 1990
Model: Aspencade
Send a message via MSN to McFirefighter Send a message via Yahoo to McFirefighter Send a message via Skype™ to McFirefighter
Hello all I need your thoughts, I went to the dark side and put a Taxi Tire on my GL 1500 I love the tire but the only problem I have is now when the better half is on with me the extra weight with her on rubs the tire. I have to run about 62 lbs of air in the OEM shock to keep it from rubbing. If I put on a set of Progressive 416 shocks will this be better then having to run that much air in the one shock. I need your thoughts I don't know what to do. Thanks MCFF
CrystalPistol likes this.
Patriot Guard Rider #144639
McFirefighter is offline
post #2 of 6 (permalink) Old 12-16-2018, 10:13 AM
It sounds like you are paying/giving up a lot for the tire. Too much air to stop the rubbing might make the bike ride really bad. The money you spend on the shocks will eat up quite a bit of the money you save on tires. Were it me I would try a smaller tire or go back to the motorcycle tire.
redwing52 is online now
post #3 of 6 (permalink) Old 12-16-2018, 01:04 PM
Bellboy40's Avatar
Year: 2000 & 1994
What is it rubbing on? There is a flap on the front part of the inner fender that the Austone tire rubs on if is not tied up better to get it out of the way of the taller tire. It could be that just getting it out of the way better would make it clear the tire. If it is rubbing on something other than that.... well... you will just have to see if it is possible to make it clear.
limpy45 and Screw like this.
Larry
-- Albert Einstein
Bellboy40 is offline
post #4 of 6 (permalink) Old 12-16-2018, 02:02 PM
CrystalPistol's Avatar
My experience … YES
The 416s have stiffer coil springs so less psi carries as much weight as well.
Screw likes this.
...(Candy Spectra Red )
CrystalPistol is online now
post #5 of 6 (permalink) Old 12-16-2018, 05:23 PM
haroldaugustine's Avatar
Model: 1995 Gl1500se
I agree with Bellboy40. It is probably actually rubbing on that inner rubber flap at the front where the inner fender meets the frame. I had that hot rubber smell after I mounted my Austone Taxi tire on my 95se. I ended up removing the flap and problem solved. Having said that, i did switch to the Progressive 416's for a much-improved ride whether solo or 2 up. The 416's are worth the price regardless of the rear tire you have.
corkya and limpy45 like this.
“Those who surrender freedom for security will not have, nor do they deserve, either one.”
1995 Honda Goldwing GL1500se
haroldaugustine is offline
post #6 of 6 (permalink) Old 12-26-2018, 09:25 AM
ALEX BERECZKY's Avatar
Model: GL1500, GL1800
I always run 91psi on my 416's, regardless of riding solo or with passenger... The bike just handles so much better that way; anything below 80psi results in the bike wandering
I void warranties
KJ6QFZ
Dark Side #590
GL1500, 1990SE, 220k miles
Rear: Austone 175R16, 50psi
ALEX BERECZKY is offline
interstate '84 air shocks vs progressive shocks question! steelhorseangel Goldwing Technical Forum 7 04-04-2013 08:25 PM
Progressive rear shocks vs. Stock 1100 shocks AndyB Goldwing Technical Forum 8 03-08-2009 07:10 PM
For sale: A pair of new progressive rear shocks (non air) for the GL1100 jtbradyl For Sale/Wanted Forum 6 04-24-2008 01:37 PM
Installing new progressive air shocks. Relocating air valve stem handyrandy Goldwing Technical Forum 8 05-04-2007 06:27 AM
Progressive 416 Air Shocks RedWinger Goldwing Technical Forum 14 08-05-2005 11:52 AM
